Y block end play?
Old Nov 10, 2019 | 01:43 PM
MARC's Avatar
MARC
Y block end play?
Anyone know what the end play should be on a 292 y block with a 312 crank?
Old Nov 10, 2019 | 02:52 PM
Tedster9's Avatar
Tedster9
Pg. 97 Charles Morris Y Block rebuild book sez "Endplay should not exceed .010 inch; .002 to .006 is the acceptable range."
It may be online, parts of it anyway. There are some techniques described how to accurately measure therein.
Old Nov 10, 2019 | 02:58 PM
MARC's Avatar
MARC
Ouch
My end play is 40 thousands
Old Nov 10, 2019 | 03:30 PM
Tedster9's Avatar
Tedster9
@hiball3985 Ask this guy, or @charliemccraney there's a way to do it described in the book but it doesn't sound good any way ya slice it.
Old Nov 10, 2019 | 05:38 PM
hiball3985's Avatar
hiball3985
Sure sounds like your thrust bearing is history. Is this a new build or how old is the engine? Hopefully the crank thrust service hasn't been damaged or was machined wrong.
Old Nov 10, 2019 | 06:16 PM
Tedster9's Avatar
Tedster9
Can someone 'splain to me why this is an issue? Can't the thrust bearing be replaced? Or different thicknesses available?
Old Nov 10, 2019 | 06:26 PM
hiball3985's Avatar
hiball3985
It's not an issue and can be replaced providing the crank thrust surface is good and still within spec. I don't know if an oversize one was ever available. Also finding why it failed is important
Old Nov 10, 2019 | 06:30 PM
MARC's Avatar
MARC
Rngine
Has 2500 miles on engine since built
Old Nov 10, 2019 | 06:38 PM
hiball3985's Avatar
hiball3985
Is it a stick or auto?
Tedster9's Avatar
Tedster9
OK. I thought it was just normal wear, high mileage thing.
Old Nov 10, 2019 | 08:40 PM
MARC's Avatar
MARC
Engine
T98 4 speed I believe
Old Nov 11, 2019 | 06:16 AM
hiball3985's Avatar
hiball3985
OK, that eliminates a torque converter issue. With out tearing it down it would just be guessing but .040 isn't normal wear with that mileage. Have you contacted the engine builder yet?
Old Nov 11, 2019 | 03:36 PM
charliemccraney's Avatar
charliemccraney
The 312 crank would have to have had the mains turned to the 292 size. Maybe they widened it in the process by mistake.
How are you measuring the end play?
Old Nov 11, 2019 | 07:52 PM
MARC's Avatar
MARC
End play
Measuring the movement of crank by the main bearings in front of #4, and 8 conn rods. Could be measuring wrong but seems quite a bit of movement of crank
arrowgap
17
Nov 26, 2018 03:55 PM
JubjubW
3.8 & 4.2L V6
Jan 27, 2011 10:00 AM
RapidRuss
67
Aug 22, 2005 07:30 AM
RapidRuss
38
Jul 7, 2004 03:24 PM
texasTBird
Mar 23, 2004 07:40 AM
