Modular V10 (6.8l)
Hanging Idle
Old Nov 9, 2019 | 08:32 PM
SMarquez's Avatar
SMarquez
Hanging Idle
2000 F250 CCSB, V10, 203k miles.
My idle is hanging or slow to return to idle which is 1000 rpm in P/N and 800 in gear. Approaching a stop sometimes it is noticeable since it takes a little more brake to stop and hold the truck. The idle hangs around 1200 rpm. I don't have any CEL's. I cleaned the MAF with the appropriate cleaner and cleaned the TB plate and pivots both in an out. The throttle cable is nice and smooth with, no noticeable effort to move it. It seems to occur a little more after a sustained running, like after a freeway ride or after towing. It runs and idles smoothly enough but this little deal is kind of annoying. It is not running away,, just slow to return to idle.
I am in the market for a new truck but I like to have my stuff working properly and don't want to pass a problem off to another owner.
So what else can I look for in my truck?
Thanks.
Old Nov 10, 2019 | 09:31 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Sounds like the IAC is sticking... pretty common.
Old Nov 10, 2019 | 06:41 PM
SMarquez's Avatar
SMarquez
OK, thanks, replace or just clean/decarbonize or whatever?
Old Nov 10, 2019 | 06:50 PM
krewat's Avatar
krewat
For the amount of work, and the cost of the part, probably best to just replace it.
Old Nov 10, 2019 | 08:09 PM
SMarquez's Avatar
SMarquez
Thanks, will get going on it.
Old Nov 15, 2019 | 01:47 PM
SMarquez's Avatar
SMarquez
OK, so I ordered the IACV from Rock Auto and got it in 2 days. I really struggled to get just one of the bolts out so I just removed the throttle body. It was actually less hassle to remove the TB to replace the IACV. I noticed that it looked like blow by from the PVC was leaking so I replaced the TB/manifold gasket for $2. I think if I had to do it again I could replace the valve again, removing the TB in 45 minutes. Anyway, it all works well and my P/N idle actually dropped a little bit. The old IACV had some moderate carbon deposits so I can see where it was causing problems.
Thanks for the heads up on this fix.
Old Nov 15, 2019 | 01:54 PM
krewat's Avatar
krewat
Nice
Glad it turned out well.
handifletch
Modular V10 (6.8l)
Jul 8, 2018 11:49 AM
whitepolarbear12
1997 - 2003 F150
May 25, 2006 09:15 AM
wrpittman2
1983 - 2012 Ranger & B-Series
Jul 27, 2004 04:25 PM
fire232
Sep 16, 2003 08:44 PM
Steve01
May 23, 2003 10:18 AM
