is breathing better better
Old Nov 9, 2019 | 08:15 PM
skeetsf250's Avatar
skeetsf250
putting in reman 5.4 3v , is worth the effort to install true duals behind the cats. its 250 sd that i mostly cruise in. like the room.
Old Nov 12, 2019 | 06:54 AM
spike0180's Avatar
spike0180
You may loose a little low end torque, you may gain a little on the top end. Overall, you likely wont feel much of a difference. But they sound cool and look nice.
Old Nov 12, 2019 | 07:08 PM
skeetsf250's Avatar
skeetsf250
thanks spike. dont do much towing- log splitter,fishin boat, and bed loads of wood. probably more interested in top side.
Old Nov 14, 2019 | 05:40 PM
Rumble phish's Avatar
Rumble phish
I will say no. Unless you like to spend that much on just sound and looks. You're not going to gain enough to make any real difference unless you do something to make your truck INHALE more air. And again, more money and not enough return, IMHO.
Old Nov 14, 2019 | 07:12 PM
skeetsf250's Avatar
skeetsf250
thanks rumble. truck is so quiet with new engine, and my hearing isnt what it used to be. i would like to hear her runnin. think i will go with a cat back, old system is shot. that way i can run duals or single
Old Nov 25, 2019 | 11:17 PM
Johnny Paycheck's Avatar
Johnny Paycheck
Not exactly true as in true duals won’t turn OP’s engine into a 4.6 and destroke the engine, but as long as he doesn’t use coffee can diameter pipes, he won’t lose exhaust flow, either.
larryb346
Mar 20, 2014 11:48 PM
03_PSD
Apr 22, 2008 12:29 AM
tarheelford
Exhaust Systems
15
Jan 10, 2006 12:25 PM
JohnC874
Exhaust Systems
May 30, 2005 08:37 PM
RandomRaider
2004 - 2008 F150
Feb 9, 2005 09:45 AM
