76 F100
Old Nov 9, 2019 | 06:14 PM
Daguy's Avatar
Daguy
76 F100
Anyone out there own a 1976 F100 360 with factory a/c
Old Nov 9, 2019 | 06:19 PM
dlburch's Avatar
dlburch
yes, I would assume a lot of people.
Old Nov 9, 2019 | 06:28 PM
Daguy's Avatar
Daguy
I have been working on a 76 for about 9years off and on getting pretty close to finishing, trying to get my heat working and I do not remember where the vacuum line at heater valve goes to to, would love some help
Old Nov 9, 2019 | 06:53 PM
jackietreehorn's Avatar
jackietreehorn
I can check my 73 360 A/C tomorrow.
Old Nov 9, 2019 | 07:00 PM
caravaggio2000's Avatar
caravaggio2000
Got a pic of the line in question?
Old Nov 9, 2019 | 07:04 PM
Daguy's Avatar
Daguy
Thank you sir
Old Nov 9, 2019 | 07:08 PM
Daguy's Avatar
Daguy
No pics working from scratch most of the original parts were lost or thrown away this was pretty much a frame off but over a 9 year stretch and move my heating and ac business in the middle of it and that’s where truck was in pieces
Old Nov 9, 2019 | 07:15 PM
Daguy's Avatar
Daguy
1976F100
I do have pics of Truck
Old Nov 9, 2019 | 07:17 PM
Daguy's Avatar
Daguy
Old Nov 9, 2019 | 08:08 PM
jackietreehorn
Damn that's a nice truck.
Old Nov 9, 2019 | 08:34 PM
dlburch's Avatar
dlburch
very nice truck. The vacuum line from the water valve under the hood goes to the temperature selector behind the dash inside the cab.
Old Nov 9, 2019 | 09:42 PM
caravaggio2000
That truck is sharp. Is all your aluminum trim just polished up or is it chrome plated?
Old Nov 10, 2019 | 01:44 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Factory installed integral A/C is combined with the heater, the A/C controls are in the same panel as the heater controls.
Large evaporator case located at the right (passenger side) rear corner of the engine compartment.
1973/79 F100/350 & 1978/79 Bronco: Bolted to the backside of the A/C/Heater control panel is this:
D5TZ-19B888-A (replaced D3TZ-19B888-A) .. A/C Vacuum Control Selector Valve Assy - Includes the "kicker" switch that turns on the A/C (Motorcraft YH-285) / Obsolete ~ 100+ available NOS
All the vacuum hoses from the blend door motors and the heater water valve connect to this valve.
D4AZ-18495-A (replaced D1AZ-18495-B) .. Vacuum Controlled Heater Water Valve - Use with factory installed integral A/C (Motorcraft YG-136) / Available from Ford.
Misc 1970's FoMoCo Passenger Cars // 1973/79 F100/350 // 1975/91 Econoline // 1978/79 Bronco // 1986 Taurus/Sable.
This valve is a notorious POS!! Gets stuck in the closed, open or partially open positions.
Old Nov 10, 2019 | 07:04 AM
Daguy's Avatar
Daguy
Thanks for the help
Thanks for the help this truck has been a long road of work my grandfather bought this truck new in 76, when he passed I got truck and started working on it
Old Nov 10, 2019 | 08:50 AM
Daguy's Avatar
Daguy
Trim
Bought all new trim grills and bumpers from LMC truck
