Alternator Bracket
Old Nov 8, 2019 | 01:02 PM
Justin Heuschele's Avatar
Justin Heuschele
5th Gear
Alternator Bracket
Hello I just bought a 69 F100. It has a 390 FE big block and I need an alternator bracket and power steering bracket. I can’t find any anywhere. Only ones I can find are through CVF racing and they want $100 each bracket. Can another bracket fit my 390 from a smaller motor? Need help finding some please
Old Nov 8, 2019 | 01:09 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Justin Heuschele
Hello I just bought a 69 F100. It has a 390 and I need an alternator bracket and power steering bracket.
Can another bracket fit my 390 from a smaller motor? No.
With or without factory A/C?
Brackets are the same as the 360, may be the same as 1968/71 390/428 from a car.
But w/ or w/o A/C makes a difference. Plus, there should be TWO P/S pump brackets, possibly TWO idler pulleys.
Old Nov 8, 2019 | 01:14 PM
Justin Heuschele
5th Gear
No factory ac. So I can order them based off a 360? A 360 small block would fit my 399 FE?
Old Nov 8, 2019 | 01:18 PM
Justin Heuschele
5th Gear
Sorry don’t know if I replied or not but a 360 small block alternator and power steering bracket would fit my 390 FE? I really would be relieved if it does bc it’s not easy finding them.
Old Nov 8, 2019 | 01:32 PM
NumberDummy
No factory ac. So I can order them based off a 360? A 360 small block would fit my 390 FE?
360/390 are FE engines, the 360 uses the same block/heads as the 390, the only difference is the stroke. No such thing as Ford small or big blocks, these are GM terms.
I'll look up the part numbers, give you the info, but these parts are been obsolete for decades, so will only be available used or possibly NOS...if I can find any.
Look at this pic, notice there are two P/S pump brackets: 3C511 & 3A732 .. 302 parts are not the same.
Old Nov 8, 2019 | 01:35 PM
1browski's Avatar
1browski
The 360fe is the same block as the 390fe. Its not a small block. Which alternator bracket are you looking for? The lower bracket holds the alternator in place and the top bracket it for the tensioning.
Old Nov 8, 2019 | 01:39 PM
Justin Heuschele
5th Gear
I need both brackets for the alternator and power steering bracket. Thank you again for your help I truly appreciate it.
Old Nov 8, 2019 | 04:40 PM
NumberDummy
I just bought a 69 F100 390 w/o A/C and I need alternator and power steering brackets
All the following parts applications except the spacer were used without A/C
C7TZ-3C511-D .. P/S Pump Support Bracket / Obsolete
1967 F100/250 352 // 1968/70 F100/250 360/390 // 1969/70 F350 360/390.
No Ford dealer or obsolete parts vendor has any NOS
C5SZ-3A732-B .. P/S Pump Adjusting Bracket / Obsolete
1967 F100/250 352 // 1968/70 F100/250 360/390 // 1969/70 F350 360/390 /// 1965/66 Thunderbird 390/428.
C8AZ-10145-A .. Alternator Adjustment Arm / Obsolete
1968/72 F100/350 360/390 /// 1968/69 Galaxie/LTD/Mustang/Cougar/Thunderbird 390 // 1970/71 Galaxie/LTD 390.
NOS PARTS SOURCE in Olathe KS has 1 = 913-220-5746.
GREEN SALES CO. in Cincinnati OH has 1 = 800-543-4959.
C8AZ-10156-B .. Alternator Mounting Bracket / Obsolete
1968/72 F100/350 360/390 ///1968 Galaxie/LTD/Mustang/Cougar/Thunderbird 390/428 // 1969 Galaxie/LTD/Fairlane/Torino/Mustang/Cougar 390 // 1970/71 Galaxie/LTD 390.
NOS PARTS SOURCE has 1.
NOS PARTS LTD in Waxahachie TX has 1 = 972-937-2201.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 1 = 800-476-9653.
D1AZ-8A652-A .. Aluminum Spacer - Use with alternator mounting bracket - 4 13/16" long - cut to fit // This spacer is round and C shaped for a bolt to pass thru / Obsolete
Myriad 1960's/70's FoMoCo vehicles.
CARPENTER has 15 & GREEN SALES has 32.
Where in CA do you live?
kevinfelix
WTB - Parts & other
Jun 2, 2011 01:05 PM
reifwj
17
Apr 13, 2008 09:33 AM
captjames
Oct 18, 2006 07:03 AM
71mopar383
Feb 7, 2006 06:31 PM
merc62
Apr 29, 2004 06:39 AM
