Power steering pump issues
Old Nov 8, 2019 | 04:20 PM
John Gomoll's Avatar
John Gomoll
Trailering
Which of those two fittings is the pressure side
Hi Y'all I am new to the group...... I need your help. I picked up my 1970 F-100 last year and I have been busting *** getting it running. My last big issue is power steering. I put in a pump. Now I need to know this... On the gearbox there are two fittings for the hoses to connect to. I need to know which of the two fittings is the pressure side. Both the fittings are the same size going into the gearbox. So I need to know which hole is the pressure hole. The one more forward or the one more toward the rear of the gear box. See enclosed photo.q
Old Nov 8, 2019 | 05:09 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Pic isn't very good, so you may not be able to see which hose goes where.
3A713 is the P/S return hose .. 3A719 is the P/S pressure hose.
Click on the pic twice to enlarge it.
Old Nov 8, 2019 | 05:49 PM
1browski's Avatar
1browski
Also, the low pressure side is probably attached to the pump with a rubber hose and hose clamp. Thats how mine is anyway.
dstraw
Jun 21, 2017 03:06 PM
ManfredVonRichtofen
Dec 18, 2011 08:02 AM
JCastellaw
1966 - 1977 Early Broncos
Oct 21, 2011 11:24 AM
nevrenufhp
Sep 17, 2011 12:19 PM
compressorguy
Dec 9, 2009 11:19 PM
