1987 f 250 leaf spring help
Old Nov 7, 2019 | 04:46 PM
BRDAVISAUTOREPAIR's Avatar
BRDAVISAUTOREPAIR
I have a 1987 f 250 40000 miles 460 truck, poor thing is sitting on the rubbers in the front. The leaf springs are so bad I want to replace them but with a bit of lift. Is there a common spring out there that will do the job or am I at the mercy of the lift companys?
Thanks, Brad
Old Nov 8, 2019 | 09:18 AM
Bronco638's Avatar
Bronco638
Contact Eaton Detroit Spring and see what they can do for you. I traded emails with the owner several years ago. He's into trucks & off-roading so I'd be very surprised if they couldn't help in some way, shape or form.
Old Nov 8, 2019 | 10:12 AM
ATS Junior's Avatar
ATS Junior
SPONSOR
How much lift? Do you still have the factory front axle up front? If so you’ll have to be careful with how much height you gain because you’ll have a hell of a time getting it aligned.
We have options that are right around 1”-1.5”
Old Nov 8, 2019 | 07:08 PM
BRDAVISAUTOREPAIR
Got some old 3 inch packs with good arch, going to start stacking I guess, nothing cheap around... what a weird front spring with the short front...
Old Nov 9, 2019 | 03:27 PM
BRDAVISAUTOREPAIR
I an just goint to ad a leaf from a rear pack then custom drop the mounts too make it work with 35 ish from my new truck. thanks everyone
Old Nov 9, 2019 | 03:38 PM
ATS Junior's Avatar
ATS Junior
SPONSOR
Good luck!
Old Nov 12, 2019 | 01:17 AM
TobyB's Avatar
TobyB
I used the ATS 'stock rate, adds 1.5" ' spring,'
and it's been just about perfect. The truck sits as near to level
as I can tell unloaded, and has very free travel in front.
Now I need to replace the sliders in the rear packs and clean THEM up.
t
StrokinIT2001
Apr 5, 2017 10:34 PM
Bowie
23
Dec 30, 2008 02:37 PM
mikedeason
Apr 3, 2006 06:54 PM
Ryan50hrl
Offroad & 4x4
Apr 9, 2004 03:50 PM
