2010 F-150 A/C COMPRESSOR IS ALWAYS ON
Old Nov 5, 2019 | 07:37 PM
FOWL1's Avatar
FOWL1
MY SON HAS A 2010 F-150 FX4 4X4 AND NO MATTER WHERE THE SWITCH IS SET, THE A/C COMPRESSOR STAYS ON. IF IT IS IN THE OFF POSITION, THE COMPRESSOR GOES OFF. HOWEVER, IF THE FLOOR IS ON OR THE FACE VENT IS ON, HEAT IS ON DEFROST OR ANY COMBO, THE COMPRESSOR IS RUNNING. IT CYCLES LIKE IT SHOULD BUT ALL THE TIME? iS THAT A SENSOR OR THE SWITCH? THE TEMP CONTROL ACUATOR WAS JUST REPLACED BECAUSE HE HAD NO HEAT. IT DID HTIS BEFORE HE CHANGED THE ACTUATOR AND NOW HE CAN GET HEAT AND A/C BUT THE COMPRESSOR IS ALWAYS RUNNING. ANY IDEAS?
THANKS,
FOWL 1
Old Nov 5, 2019 | 08:10 PM
ford390gashog's Avatar
ford390gashog
The compressor runs in all positions except for off. It should cycle in all positions but stay constant in AC mode.
Old Nov 6, 2019 | 08:07 AM
alloro's Avatar
alloro
I believe it's also off when in straight floor or vent modes (no mixing.)
Old Nov 7, 2019 | 04:30 PM
FOWL1's Avatar
FOWL1
NO, IT ONLY SHUTS OFF WHEN THE SWITCH IS OFF. HE JUST REPLACED THE ACTUATOR(THE ONE BEHIND THE RADIO) BECAUSE HE HAD NO HEAT. HE NOW HAS HEAT AND A/C, BUT THE COMPRESSOR RUNS ALL THE TIME. IS THERE A RELAY THAT COULD GO BAD OR THE SWITCH PANAL OR MAYBE A DIFFERENT ACTUATOR. WE JUST DON'T WANT TO BURN THE COMPRESSOR UP BY HAVING IT RUN ALL THE TIME. ANY THOUGHTS?
Old Nov 8, 2019 | 06:24 PM
tjc transport's Avatar
tjc transport
i ain't rite
as said, the compressor runs in all positions but off. there is nothing wrong with the truck.
Old Nov 9, 2019 | 06:43 AM
FOWL1's Avatar
FOWL1
unless I MISSED SOMETHING, THE COMPRESSOR SHOULD RUN IN A/C, DEFROST AND DEFROST/FLOOR MODE. THAT IS THE WAY ALL OF THE OTHER FORDS I HAVE WORK. STRAIGHT FLOOR HEAT = NO COMPRESSOR, PANAEL HEAT OR VENT =NO COMPRESSOR. I KNOW THINGS AREN'T AS THEY USED TO BE WHERE IF YOU PUSH THE A/C BUTTON, THE COMPRESSOR COMES ON AND IT MAKES COLD AIR. I KNOW THERE ARE ALL KINDS OF RELAYS AND RESISTOR SWITCHES ETC... THAT IS WHY I'M ASKING IF ANYONE HAS HAD THIS ISSUE AND WHAT THEY FOUND. MOST HAVE THE ISSUE WHEN THE ACUTUATOR BEHIND THE RADIO GOES BAD HAVE THE HEAT IS ALWAY ON. THIS TRUCK THE A/C AMND COLD AIR WAS ALWAYS ON. (THERE IS SOME SORT OF SLIDE INSIDE THE ACTUATOR THATGETS STUCK. WE CHANGED THE ACTUATOR AND NOW HAVE HEAT, BUT THE A/C COMPRESSOR ONLY TURNS OFF IN THE OFF POSITION.
IF IT IS SUPPOSED TO BE ON ALL OF THE TIME, THEN FORD MUST HAVE CHANGE IT UP IN 2010 BECAUSE WE HAVE A 10 RANGER, 10 EXPLORER, 03 F-150, 13 F-150. ALL OF THESE ARE AS STATED ABOVE, WHERE THE VENT, PANEL AND FLOOR HEAT DO NOT RUN THE COMPRESSOR.
ANY OTHER SUGGESTIONS?
tHANKS
Old Sep 20, 2024 | 08:18 PM
Denmen's Avatar
Denmen
1st Gear
Did you ever find out the cause of the problem? My truck is doing the same thing.
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
Sep 30, 2016 07:51 AM
Roasted7
Mar 19, 2012 12:19 AM
tps93ranger
Nov 17, 2008 10:50 PM
mfriesen
Oct 31, 2004 02:12 PM
Oldchap
Nov 19, 2002 07:01 PM
