I am thinking it must be the assembly up in the column.
I already have the steering wheel off, so now I have to wait another week, to be able to buy the parts, and I have only had the truck home a few weeks, and haven't gotten a manual yet. So, between now and next week, if anyone has any pointers that could make all of this a little easier, bring it on, and thanks for the help......I really like this site!
The funny thing is, that I passed up working on the Mustang tonight, because I have to pull the upper plenum and fuel rail to change the fuel pressure regulator on it, thnking this would be an easier project!!
O well, I think I am going to go sleep on it.
Thanks again....
Mike
Can you take the switch off the column and turn the ignition switch? Does the rod move? That should tell you if it's something in the actuator up in the steering wheel or something wrong with the way you put the ignition switch on.
Take the switch and make sure it has the spring back in it. The only thing the lock does is make it so it can't be stolen. The only thing the rod dos is transfer motion. If the switch has the spring then maybe the rod is binding for some reason.
Wow, mine just did the same thing yesterday morning after it had been sitting waiting for calipers, needless to say it really ticked me off that once the brakes were finnaly done it just had to have something stupid like this happen, haven't driven it all week.
I am still not sure that this will cure my problems though.
Is the actuator a dealer item??
My Father-in-law gave this truck to me. Like you said, mine's been sitting awhile too.
I had the truck tuned and ready to go. Took her her up to the gas station, and on the way back, for no readily apparent reason, she started cutting out.
20 minutes later I got it started again, and started cruising down the road, and cut out again. No backfiring, no sputtering, no spark knock, no smoke.
I do this grind two more times, and when I am less than 200 yards from the in-law's house, the tumbler loses it's springback, and I am stuck in neutral.
I lose the priming to the fuel pump, and though I have all of my accessories (lights, fuel gauges, temp gauge, radio), I can't get it to turn over. I can jump the solenoid, and she turns over, but won't start. I thought that maybe the high pressure pump went, and while hitting the key so many times trying to get it started it toasted the igntition switch.
So I figured I would start at the tumbler, then the switch, and go on from there......
But the more I am digging, the less certain I am of what the actual problem is.
hey buddy. i think i had the exact problem you have. i turned the key forward and it wouldnt turn back one day. and after that, when i turned it forward, nothing even happened. i dont know if you fixed it yet or what, but ill tell you what i had to do. take the steering wheel off. take the shrouds for the colums off. when you turn the key, does the little rod thing move? if there is alot of play in it, then i know whats wrong. if youre still having problems, let me know and ill help you out. i dont want anyone else to have to go through the crap that i had to! thanks.
The rod is supposed two have two legs. One for the ignition switch, and one for the shift lever lock. The lower leg is broken off on mine, and allowed rod to float with respect to the lock.
So, I have it all apart now, and am curious as to if the rod is a dealer item, or an aftermarket.......
