Tow Shifting Issues
Old Nov 4, 2019 | 06:03 PM
ymsmiley's Avatar
ymsmiley
Tow Shifting Issues
Went up north this weekend and my 2018 6.7L felt like it was shifting poorly while towing. Wondering if anyone else has experienced this or if I should take it in
It was smooth the entire time pulling my 7500 lb toy hauler except the elevation change of 4-6% grades. Going uphill it would struggle to find the right gear and often stayed in lower gears. This makes sense except that it was really close to redlining and stayed there despite me trying to pedal it to find a better gear. Though downhill it kept staying in 3rd gear and I couldn't get it to change gears there either. I get all this but the engine was really overworking at the time. Trany temp was 224F. Tow/Haul on/off didn't seem to have any affect. I wasn't in manual shift mode but it wasn't a good place to pull over anyway.
My guess is something to do with the PRS (Progressive Range Selection). Any ideas?
Old Nov 4, 2019 | 07:37 PM
klbrown's Avatar
klbrown
I've had that happen a few times as well. Uphill it downshifts too late and then jumps two gears.
After going downhill it stays in a lower gear for longer than I think it should. As you said, the rpm's
are too high already to try to get it to upshift by accelerating.
Usually, for me, turning off Tow/Haul until it upshifts works.
I also manually downshift going up hill using the +/- button on the shift lever.
Old Nov 4, 2019 | 08:56 PM
Mattm400's Avatar
Mattm400
I think it also senses the angle at which the truck is. I've noticed mine will hold a gear even when not towing going up an incline. Even if I lighten up on the peddle it will still hold until the truck levels out. It knows more about where it is than we do sometimes.
Old Nov 4, 2019 | 08:57 PM
ymsmiley's Avatar
ymsmiley
Sounds pretty similar. You ever have the dealer look at it?
Old Nov 5, 2019 | 12:26 AM
HRTKD's Avatar
HRTKD
Staying in too low a gear for too long on a downhill run while towing is not uncommon around here. I don't have any shifting issues going up hill. I point it uphill and it does it's thing very well.
Old Nov 5, 2019 | 04:06 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
You don't have to pull over to shift to manual mode.
Old Nov 5, 2019 | 07:05 PM
Desert Don's Avatar
Desert Don
^^^^^^^^ here ya go. Put gear selector in “M”, use the +/- button on the gear selector to choose which gear you want, just like a manual, but without the clutch.
Old Nov 6, 2019 | 05:19 PM
acadianbob's Avatar
acadianbob
I agree! I think the inclinometer (sp?) is involved in whether the truck decides to upshift. I think it delays upshifting if it senses climbing is going on.
Old Nov 6, 2019 | 06:25 PM
ymsmiley's Avatar
ymsmiley
I'm wondering about why, not how to manual shift. It all made a little sense but concerning it would get so close to redlining but never shift, if even for the sake self-preservation. The motor sounded really strained, more so then just high RPMs, which is why I considered pulling over. With torque peaking at 1800 RPM and HP at 2800, a sustained 3800-3900 was too much
Old Nov 6, 2019 | 07:09 PM
klbrown's Avatar
klbrown
No. It happens so seldom. For me it usually happens when towing and in cruise control. Cruise
control always seems to be slow to adjust to speed and terrain. Up hill it downshifts 2 gears where
if I manually downshift one gear I can pull the grade.
Down hill I set the cruise to at least 5mph slower than I want to go and it will hold the speed I actually want.
Old Nov 6, 2019 | 07:38 PM
Work Truck Fanatic's Avatar
Work Truck Fanatic
I had this issue going down hill so I shiftedinto manual and hit the plus button to bring the RPMs down. At that moment I had the engine brake on. Others have suggested using the EB in auto mode instead but I havent had a chance to test this.
Old Nov 6, 2019 | 10:07 PM
Joe T's Avatar
Joe T
Sounds like you were running up and down elevations and working it. Try slowing down and manually shifting it. You can carry a little more speed without straining it if you know what you are doing and take over sometimes; its not like a computer can see a hill or notice grade changing gradually.
If its getting hot with 7500lbs then you are really letting it search gears. Is that the actual weight or dry? Lots of headwind?
Midnightmoon
2015 - 2020 F150
18
Feb 18, 2019 10:44 AM
Bruce2017
Apr 5, 2017 10:17 AM
okie2020
Dec 15, 2013 02:48 PM
meborder
Sep 28, 2012 08:23 AM
GR8Dane
6.7L Power Stroke Diesel
Nov 15, 2011 09:26 AM
