My 2010 F350 V10 gasser has an engine block heater. Tested it today and looks like it draws around 625w. I'd probably put it on a timer/controller to turn on it at specific times, but I'm curious what you guys think as far as how cold it really needs to get before running these block heaters really makes much of a difference. Thanks
my plow trucks (one 5.4l and one 6.2l) have always started fine sitting out in the cold. think the coldest may have been close to -25f. i use remote starters to get them going so that they’re warm and defrosted by the time i get into them.
i think i used the block heater once to test it out.
biggest factor in cold is the condition of your battery; newer battery with the highest cca available is the best
i do use the block heater in my diesel skidsteer, but that’s a little different
GENERALLY anything at or below 0° F. for a gasser. But it depends on what you're aiming for when you say "make a difference", in terms of just getting heat in the cabin quickly I'd start at around 20°F., for a Diesel anytime it gets cloudy or overcast. /s
Having lived and worked in the far North where the temps can stay -40F for weeks on end, a cold start is extremely hard on any engine. A block heater helps with warming up the coolant in the block, but dose nothing for the engine oil sitting in the bottom of the pan. I like to use a magnetic oil pan heater to help with the lubrication of the bearings, etc. during a cold start up. My old 1993 F-350 was a military truck that was used up in Fair Banks AK. This truck had two block heaters, one on each side of the engine, a magnetic oil pan heater for both the engine and transmission and also a heated battery blanket for the Battery. The truck is still running strong to this day.
Any time it's below freezing outside the heater is a benefit. Not only will the engine start easier, the heat and defrosters will come up a lot faster too. FYI, for 625 watts at .12 a kilowatt that's $.075/hour or .60 to run the heater for 8 hours. If you did that every day the heater will cost about $18 a month to run. Sorry for the math, that's the electrician in me.
Energy saving tip, run your block heater on a timer so it comes on a hour before you leave in the morning. No need to run it all night. Of course, we almost never use ours, and it does get cold where I live. I actually think throwing a battery tender/maintainer on during the coldest nights makes a bigger difference, but that's not a popular opinion . . . .
Obviously you have never been around a 6.7 PowerStroke!!!!!!!! LOL Both of mine started better than either the 5.4 gas or the 6.2 gas. I had them all.
Diesels don't tend to warm up as fast do they? That's kind of what I was getting at. My only experience with diesel engines was in the .mil, though they didn't seem to like cold weather very much. They would start eventually, but it took a while, now and then we had to start the whole motorpool at once, and much hilarity would ensue.
Getting back to the original question, How cold before engine block heater really helps? IMO, to many variables involved to give a specific temperature. No two engines gas and or diesel will act the same when trying to start them in the cold. Cold temperatures and a vehicle that will not start is a good indicator that something needs to be addressed. Whether it's an old battery that has no cranking amps when cold or something as simple as cleaning the terminals. Cold weather seems to almost always find the weakest link and will cause a cold no start condition. It's safe to say, anyone who have lived in or grew up in -0 F conditions has a very clear understanding what it takes to start their vehicles in the cold. Whether it's the luxury of having a heated garage or your vehicle having to be plugged in all night because it's sitting out in a 4' snow bank, -10 F with a -35 F wind chill on top. Keeping good vehicle maintenance really helps in these types of cold weather conditions. This all being said with 40 years of cold weather vehicle survivor skills.
