Can't Install Injectors when using head studs
Old Nov 1, 2019 | 07:43 PM
ChrisMelton78's Avatar
ChrisMelton78
So, I have a 1995 F250 7.3 Powerstroke. I decided to use head studs because I plan on making a significan't amount of horsepower. I installed the head studs, put the heads on, and torqued all of the bolts down as directed. Now I can't seem to install the injectors because the top bolt (next to the oil squirter) will not tightened down because of the head stud sticks up too far. I tried removing the cover of the injector to see if I could get a better position to tighten down the top bolt, but it doesn't seem to work.
ANY IDEAS???
Old Nov 1, 2019 | 08:05 PM
PSU4ME's Avatar
PSU4ME
I’m not much help but take a read here and see how it grabs ya
https://www.powerstrokenation.com/fo...#/topics/63223
Old Nov 2, 2019 | 07:04 AM
427 fordman's Avatar
427 fordman
The stud kit should have had shorter studs for the injector area, with directions
Old Nov 2, 2019 | 07:51 PM
ChrisMelton78
Ya know, I thought about that before I got started and lined all of the studs up and they are all the same size. So strange, huh? So, right, wrong, or indifferent, I just removed the studs under the injectors and used the head bolts instead of the studs. Aside from trimming the stud with a cutoff wheel, I didn't see any other solution. I'm still open to suggestions, however!
Old Nov 3, 2019 | 09:04 AM
fordman67's Avatar
fordman67
The directions tell Wich holes those specific studs go in. They also tell how high they should protrude or be less than. My bet is the head bolt holes are obstructed by something.
Old Nov 3, 2019 | 09:56 AM
z31freakify's Avatar
z31freakify
Did you air blow the holes before installing the studs?
Old Nov 3, 2019 | 10:23 AM
oldbird1965's Avatar
oldbird1965
Isn't it true you shouldn't reuse stock head bolts?
Old Nov 3, 2019 | 10:29 AM
z31freakify
Actually they are re usable in the 7.3 Glenn.
Old Nov 3, 2019 | 10:57 AM
Hit Man X's Avatar
Hit Man X
Are these ARP studs and from a known retailer? 7.3 head set seems to run $650 from what I have seen.
Running bolts and studs will have different clamping force around the cylinder. Seems like a problem waiting to occur.
Zjrebel
Jan 8, 2016 10:06 PM
mongo75
Oct 5, 2010 08:04 AM
jk_hooper
Oct 3, 2010 11:28 PM
FFemt5287
Oct 22, 2007 06:28 PM
BoostLover
Dec 18, 2003 08:46 AM
