2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
P2135 Code Intermittently
Old Nov 1, 2019 | 02:29 PM
Bill Ward's Avatar
Bill Ward
I bought a 2010 Expedition XLT and after about a day it started throwing p2111 and p2135 OBD codes. I have since replaced the throttle body which seems to have fixed the p2111 codes. I reset the computer by unplugging the battery and reattaching it then letting it idle for a good 20 minutes to relearn the throttle position. I also replaced the accelerator pedal and it ran great for about a week but now it is throwing multiple p2135 codes again. Not sure what else to try next. Any ideas on what I can check or replace next? Thanks in advance!
Old Nov 2, 2019 | 09:59 AM
alloro's Avatar
alloro
It might be an issue with the pigtail connector's contacts being oxidized or loose.
Old Nov 2, 2019 | 11:19 AM
Bill Ward's Avatar
Bill Ward
That makes sense. I got some quick drying electronics cleaner and sprayed the pigtail to the accelerator pedal since the p2135 codes relates to it. I also scraped the contacts with a dental pick type thing. Now that I had a good look down there it could also be my big feet hitting the cable that goes to the pigtail. I anchored it up a little higher to make contact with my foot nearly impossible. I will give it a try and see if that code pops up again.
Thanks!
rscamaro305
34
Oct 29, 2011 03:28 PM
mailmanshears
2004 - 2008 F150
Sep 20, 2010 06:23 PM
mlytc
Feb 28, 2010 01:29 PM
GIXXED
1978 - 1996 Big Bronco
15
Aug 6, 2006 11:12 AM
Mass20
Dec 15, 2004 11:00 PM
