Sponsored by: Auxito
Anyone install Cal-Van spark plug thread insert. Pic request, or verification.
Old Oct 30, 2019 | 05:46 PM
Quick Cal's Avatar
Quick Cal
I have my head off doing a wrist pin change. That's another thread. Don't know if this caused it or not but the guy I got this truck from did a thread repair on 1 plug hole. Now that I have the head off I can see he either did the install wrong, or the insert is backing out.
The spark plug needs to go another 5/16'' deeper into the hole. I can see where the insert is not threaded in all the way. I THINK. There is a chunk broke out of the bottom of the spark plug hole which I'm guessing my friend did when he did the insert.
I don't see any type of jb weld, or thread sealer which makes me think it might be backing out. I tried putting a spark plug in from the wrong side and screw it through. But I got scared and stopped. I wonder if I could use a proper size bolt from the wrong side and try to un-install the insert. Might get lucky if it doesn't have sealer.
So I can't find a pic of how deep the Cal-Van insert goes in. But I found another companies pic. It goes to the bottom of the spark plug hole, which I would assume so would the Cal-Van.
Anybody know for sure.
This is the other companies. Not sure what company.
This is how deep the my other plugs are.
And this is the one with the insert. The plug is flush with the bottom of the hole. The electrode is flush with the bottom of the hole.
Do you guys think this would effect performance and needs fixed. Or leave it as is.
__________________
Old Oct 30, 2019 | 09:45 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
If it is backing out, you probably should fix it. If not, and assuming it was running fine before you took it apart, I'd leave it be.
Old Oct 30, 2019 | 09:56 PM
ford390gashog's Avatar
ford390gashog
The head is junk, that was a improper repair insert. No fixing that as the casting is gone.
Holaho
Dec 18, 2017 12:15 AM
trun10tion
Oct 23, 2015 02:20 PM
papajoemrt
1997 - 2003 F150
20
Apr 30, 2009 09:47 PM
cabldawg
3.8 & 4.2L V6
Dec 23, 2008 07:26 PM
ronnadavid
Jul 9, 2008 08:38 PM
