I haven't found any vehicle review YouTube channel that does a "great" job of the technical details, but maybe that's because any that try it don't get the clinks. Remember, YouTube is an entertainment business, and being informative is a secondary goal for most channels.
I think AlexOnAutos is pretty good at factual/technical reviews if you haven’t checked him out.
Looks like the Sterling is the way to go with the 7.3 after all.
All in all TFL has improved over the years but I agree they don't give true enthusiasts anything to write home about. At least their early access to new production vehicles is nice.
Originally Posted by 00t444e
I would take a Sterling axle over the the Dana m275 any day. The new Dana axle has very little aftermarket support, and what is available is expensive. The Sterling 10.5 has tons of aftermarket support, there are dozens of limited slips, lockers, and gearsets available for it, and it is one of the cheapest HD axles to buy parts for.
The best bet for better mileage is a long tow; as in a couple of thousand miles. The differentials need to loosen up to get better mileage.
That makes little difference, a new differential shouldn't be tight, the pinion pre-load is only 20-40 inch lbs on most axles, which is very little, considering the weight and wind resistance of the truck.
Very early with just 1 week driving but unloaded I'm getting 12 mpg.
I've never noticed much of a difference break-in, and 12 sounds about right for mix driving. Have you paid attention to the mpg meter while cruising on the highway?
Something changes after a few thousand miles. Both of my new SDs MPG improved afterwards.
Yes, I agree. IMO, the differentials get worked in . . . close to 2 MPG improvement in my case. The break-in Ford wants before towing is for the differentials, not the engine. When my truck was new, releasing the throttle was like throwing out a huge boat anchor. Now it will coast somewhat better.
Big Truck Big Rv is pretty good with technical details and non bias reviews but you will not get mpg testing
On my V10 there was a lot of discussion about the programming changing after a couple thousand miles. Many guys noticed an improvement after 3-5k miles in performance and MPG.
That could still be the case with new engines. Outboard marine engines are the same way.
This short clip may have already been posted, but it’s pretty good I think. I drove a 7.3 3.55 a few days ago and personally I was impressed. I would also like to drive a 4.30.
