7.3L / 6.8L V8 Gasoline Engines Discuss the new 7.3 and 6.8L Gasoline V8s
7.3 First Drive
Old Dec 10, 2019 | 08:53 AM
Akley88's Avatar
Akley88
those photos are making me wish i waited for the 7.3. so when will dyno results be available?
Old Dec 10, 2019 | 09:04 AM
5 Star Tuning's Avatar
5 Star Tuning
Former Vendor
dyno info coming soon, we will have the 6.2L VS 7.3L to wheel so everyone can see the real differences both in stock form and tuned form
Old Dec 10, 2019 | 09:19 AM
ExxWhy's Avatar
ExxWhy
Is this TFL truck a regular production vehicle?
Old Dec 10, 2019 | 11:27 AM
prairie-650's Avatar
prairie-650
well if it is a production vehicle there goes any hope for a larger fuel tank on the ccsb gas trucks. Misprint again I guess.
Old Dec 11, 2019 | 04:15 PM
papecat's Avatar
papecat
Sucks the 7.3 has a sterling instead of the m275
Old Dec 12, 2019 | 05:24 AM
5 Star Tuning
Former Vendor
yes this truck is a production type vehicle BUT its used for the press people and is shared around the country by all of them, might even see some of them at the Ford Press Event coming in Jan 2020
Old Dec 12, 2019 | 06:04 AM
dnewton3's Avatar
dnewton3
Why? What's wrong with the Sterling? It's a proven unit fully capable of the task. The 7.3L only puts out 475 ft-lb; it's not anywhere near the Sterling limits of stress. The Sterling has held up very well behind far "torque-ier" engines than this.
The Dana has bigger capacity mainly for loads; it can carry more weight - which is why you see it in the F450 and up. The M275 also has more friction losses and unsprung weight.
I, for one, like the Sterling. Nothing wrong with it. Good reputation. Great aftermarket support. What's not to like?
Old Dec 12, 2019 | 06:07 AM
dnewton3's Avatar
dnewton3
Originally Posted by bryced15
Andre said he was hoping for a better towing gear, but that’s what Ford sent them.
That won't stop Andre and company from making assumptions, and giving advice based on uninformed opinions and general bias ...
Old Dec 12, 2019 | 06:13 AM
dnewton3's Avatar
dnewton3
- Anyone notice that the t-stat housing seems to be DIRECTLY under the upper intake manifold just downstream from the throttle plate? I can only presume the intake must come off for the t-stat change? Am I seeing this right? Oh - now that's just brilliant ...
- And is that a plastic tranny pan (shrouded in heat shield between the Cats) for this new 10-spd ???
Old Dec 12, 2019 | 06:36 AM
dnewton3's Avatar
dnewton3
deleted comment.
Old Dec 12, 2019 | 08:01 AM
h20camper's Avatar
h20camper
Doesn't the F450 (and DRW F350) get the Dana 300. The Dana 275 is only on F250 6.7 HCTPs and F350 6.7s.
Old Dec 12, 2019 | 10:00 AM
ExxWhy's Avatar
ExxWhy
Looking at some older videos of the introduction with the engineers, looks like there is plenty of room to get the t-stat out without removing the manifold.
The trans pan is a "composite material" used to save weight. As per the trans engineer in one of the intro videos from last winter. It's probably fine, but even in worst case scenario, easy to replace.
Old Dec 12, 2019 | 10:26 AM
  #28
sky Cowboy's Avatar
sky Cowboy
Weird to have so much criticism from people over a truck they don't own, and haven't put 100k miles on, to actually discuss the issues they have personally had with it.
It reminds me some of how people were telling me that I made a mistake buying a bunch of Mack and Volvo trucks, and how they wouldn't take the daily abuse my driver's give them. Yet they have been extremely reliable!
Old Dec 12, 2019 | 01:31 PM
  #29
dnewton3's Avatar
dnewton3
Don't get me wrong ...
I like the concept of the 7.3L gasser and all that it promises. I am biding my time for a couple years to let the unforeseen issues be ironed out. Will drive my 6.2L truck and then upgrade perhaps in 2022? But I'm a guy whom does ALL my own maintenance, and so if the t-stat is crammed under the intake, I'm going to be cursing someone when I go to change it. As for the trans pan being polymer/plastic/composite or whatever you want to call it, well, I'm OK with that also, as long as it holds up well. Plastic fuel tanks have all but eliminated corrosion issues. Plastic fuel lines offer the same thing. I'm not at all against a non-metal product being used for the trans pan, IF it holds up well.
I used to be all about the mostest/fastest/baddest-*** ________ my money could buy. Now, I'm much more concerned about something that runs decently, holds up in the long term, and has ease of service in mind.
Old Dec 12, 2019 | 07:34 PM
  #30
acadianbob's Avatar
acadianbob
Yep . . . . can't believe some of the stuff I hear . . .
