Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Portable Generator
Old Nov 2, 2019 | 02:17 PM
Beechkid's Avatar
Beechkid
Originally Posted by ford390gashog
Yes this is true for lots of applications, those units are also minimum 10k new and are all diesel powered by Kubota 3cyl engines and various head manufacturers, lots of these units are repackaged by MQ power.
Not quite...they are available in gasoline or diesel or can be permanently run off the vehicle fuel tanks..... and they are available in 1.5k versions as well for much less than $10k...here is a 3700 watt gasoline generator for $1,049 USD... that is even CARB compliant
https://apelectric.com/cummins-onan-...4500i%20(11400)
IMHO, for a residence, I would personally go for a 5,000 watt unit....this would be more than enough to power up all essential appliances including the refridge.
Old Nov 2, 2019 | 02:36 PM
tjc transport's Avatar
tjc transport
i ain't rite
those units are only 120 volts, and chinese made though.
for a whole house unit, i would want 220 volt capable and consider 5000 watt constant a bare minimum
Old Nov 2, 2019 | 03:46 PM
daveengelson's Avatar
daveengelson
Appreciate comments and suggestions. With regards to Honda kinda looking at their selection of portable generators whether I go with an inverter or standard gas generator, at half the price considering I am looking at the 220V units, and the dealership and service center local and manufacturer reliability.
I searched and found there is suppose to be an Onan dealership and service center relatively close, attempted to call them w/ no answer, intend to try again on Monday.
Old Nov 6, 2019 | 11:36 AM
Bronco638's Avatar
Bronco638
Hi Dave,
My parents live outside of Santa Rosa and just bought a dual fuel unit so they wouldn't keep having to replace food items and have some heat. I kinda wish they had read thru this thread before deciding on what to buy.
That said, where are you in CA? I'm a member of a motorcycle-oriented forum site. One of the inmates is selling a Honda EU7000is generator. He's in Las Vegas. If you're in SoCal maybe you guys could meet half way (or something).
Here's what he posted:
I bought this new a few years ago to use on my RV. I've sold the RV and have no use for it now. Has about 200 hrs run time. Serviced every 50 hrs. New battery. Located in Las Vegas. Price is $3800
Engine Honda GX390 EFI
Displacement 389cc
AC Output 120/240V 7000W max. (58.3/29.1A) 5500W rated (45.8/22.9A)
Receptacles 20A 125V GFCI Duplex (2), 30A 125V Locking Plug, 30A 125/250V Locking Plug
DC Output N/A
Starting System Recoil, electric
Fuel Tank Capacity 5.1 gal.
Run Time per Tankful 6.5 hrs.@ rated load, 18.0 hrs. @ 1/4 load
Dimensions (L x W x H) 33.4" x 27.6" x 28.4"
Noise Level 58 dB(A) @ rated load, 52 dB(A) @ 1/4 load
Dry Weight 261 lbs.
Residential Warranty 3 Years
Commercial Warranty 3 Years
If you're interested, I can see if he'll reply to me and I can get his contact info.
Let me know, Dave.
ps - I have a Honda EU2000i with the companion unit. I bought them when Honda dropped the 2000 and introduced the 2200. I use them to power my small camper (which has lights and A/C). I figure that in a pinch, I could use them to run the fridge and freezers so that we wouldn't lose all the food. I'd have to figure out something else for the furnace (if it was cold outside). I can deal without A/C for a while, if necessary. Given the previous posts, I know that the 2200s are not what you're looking for but I figured I add my $0.02.
Old Nov 7, 2019 | 10:47 AM
daveengelson
Originally Posted by Bronco638
Hi Dave,
Displacement 389cc
DC Output N/A
Dry Weight 261 lbs.
Let me know, Dave.
Would not U know it, spent Wednesday shopping for Honda Generator, primary interested in the Dealership with the best customer reviews, went with the EU70001, with Ca. utility issues there has been an influx of orders for portable generators, the dealer advised it should not take more than 7-10 days for the generator to arrive?
I thank you for the information it's the story of my life a day late and dollar short.
Old Nov 7, 2019 | 12:31 PM
Bronco638's Avatar
Bronco638
Well, I know that portable generators were N/A in SR until the local Lowe's scraped together a truck load and offered them 'first come, first served'. My Dad planned to be in line two hours before they opened (this was last week while the Kincade fire still raged) but ended up going in a different direction. So, I hope what the dealer is telling you is true. However, if you'd prefer to contact the guy in Vegas, I'd be happy to try to contact him for you.
Old Nov 7, 2019 | 04:55 PM
daveengelson
Stopped by the Honda dealership today and was behind a customer who ordered the EU2200i and advised he would be placed on a waiting list of 34 prior customers and they did not know when his generator would arrive as the manufacturer would be gradually distributing them among the other NoCal Honda dealerships. Appears I am in the same boat, close to requesting my deposit back?
Old Nov 7, 2019 | 05:36 PM
Beechkid's Avatar
Beechkid
IMHO, although Honda engines are good, sometimes getting parts is a pain and typically priced very high...so personally, I have always avoided.
Old Nov 8, 2019 | 08:49 AM
Bronco638's Avatar
Bronco638
My offer still stands Dave. I can try to contact the seller before you ask for your deposit back. That way you don't lose your spot in line, as it were.
Interesting you say this. I've always found Honda to be very good about supporting all of their products. Yes, you'll typically pay more for OEM parts but you'll also know they'll work. I've never had any issue getting parts for any of my Honda products (current & past).
Old Nov 8, 2019 | 10:32 AM
daveengelson
I was seriously looking at the Champion Dual Fuel electric start generator, neighbor purchased 1 and pleased with it. Unfortunately, Honda does not make a dual fuel generator, perhaps because of the Ca. Toxic gasoline they make money on carb. replacements or repairs. As I mentioned, I went with Honda because it is the only generator manufacturer that I am aware of that offers a few dealerships and certified repair services in my area. In reading Champion warranty fine print it appears that if the generator needs repair the customer pays the cost of creating and shipping to the certified Champion service center. In speaking with the manager, at this time, the demand for the EU7000i is not as great as the EU2200 so he does not believe I will be waiting long for the generator.
Bronco 638, I appreciate the information but I am pretty much set with purchasing directly from the Dealership that way if I get a lemon, or have a problem I have a face I can vent to. Again I thank you.
I do appreciate comments and suggestions!!
Old Nov 11, 2019 | 01:11 PM
Bronco638's Avatar
Bronco638
Hey, no problem!
Old Feb 7, 2023 | 04:52 AM
Adam Wilson's Avatar
Adam Wilson
2nd Gear
Based on the information you've provided, it seems like the Champion 7500-Watt Dual Fuel Portable Generator would be the better choice for you, given that it can run multiple appliances and has the option to use either gasoline or propane. However, the extended warranty offered by the big box home supplier is questionable, and it's important to consider the quality of support and repair services offered by the manufacturer.
Additionally, it might be worth considering other brands that offer dual fuel options, as well as warranty and repair services. Some popular options include Westinghouse and Generac.
It's also important to consider the noise level and weight of the generator, as well as its fuel efficiency, to make sure it's the right fit for your needs. I would suggest reading customer reviews and conducting further research before making a decision.
KC8QVO
All Things Towing
24
Oct 10, 2019 08:46 AM
RV_Tech
All Things Towing
Jun 16, 2016 04:08 PM
PAVEMENTMAN
15
Jul 30, 2009 11:14 PM
morning town express
Garage & Workshop
Nov 7, 2005 11:33 PM
GotLift
Garage & Workshop
30
Oct 10, 2005 09:45 PM
