General Automotive Discussion
sketchy brakes
Old Oct 28, 2019 | 11:36 AM
Efrain Murillo's Avatar
Efrain Murillo
sketchy brakes
Hello I am new to this website and first making a post. I have a problem with my ford f150, when ever you press on the brakes it only stops with one (for me its the driver side rear drum) and its been like that for a while. now the fronts also do activate however it primarily seems to stop with just the one. about a year and a half ago me and my dad replaced both rear drums when it happened. and just yesterday we took off the passenger side and inspected it, we noticed the wheel cylinder did not move so we replaced it with a new one. but when he went to test it it did nothing (but now when you want to stop its almost as if it does not want to, might have to bleed the brakes). anyone have this happened to them or something similar could help us that would be greatly appreciated. the truck is a 1997 ford f150 4.6 v8 extended cab with 2wd.
Old Oct 28, 2019 | 02:07 PM
meangreen92's Avatar
meangreen92
Definitely need to bleed after replacing a wheel cylinder. Sounds like it might need the fronts bled too. Is the brake warning light on?
Old Oct 28, 2019 | 03:02 PM
Efrain Murillo
No brake or abs light is on
Old Oct 29, 2019 | 07:42 AM
BIGKEN's Avatar
BIGKEN
Moved from GAC.
Gettysburg150
Mar 25, 2013 10:26 AM
Manwith3fords
Jan 7, 2007 07:50 AM
J. O'Keefe
Sep 16, 2005 06:46 PM
67CAT!!
Jan 7, 2000 09:31 PM
jack83
Dec 10, 1999 04:01 PM
