Rear Sump?
Old Oct 28, 2019 | 05:09 PM
Subsailor1127's Avatar
Subsailor1127
Rear Sump?
Hello all, just to clarify. The current engine in my truck is a Y block with a front sump/pickup. They Y block has the standard front motor mount under the dampener and then the two on the side back by the tranny. I am contemplating changing out the Y block for a small block Ford (most likely a crate motor) and I understand I will have to change the motor mounts. I believe I will also need a tranny cross member to go from the current 4 speed manual "truck tranny" to either a C4 or C6. Most information I have been able to find/research indicates that I when get a small block Ford motor, I need to get a rear sump/pickup. I am not in any hurry at all and just starting my research, but this is one of the things I want to make sure of at this point. Thanks.
Old Oct 28, 2019 | 06:46 PM
56panelford's Avatar
56panelford
Either way if you are staying with the stock suspension or going with an after market Mll cross member you need a rear sump..
Old Oct 28, 2019 | 07:14 PM
Subsailor1127
Thanks John, staying with the stock suspension for now anyway.
Old Oct 28, 2019 | 07:18 PM
56panelford
With the stock suspension a front sump would make contact with the solid axle and why the sbc was favored before rear sump pans could be had for the Ford motors..
jav_eee
Dec 10, 2017 12:57 PM
mr_malina
Sep 23, 2017 01:09 PM
GM4WALLS
Dec 24, 2013 10:22 PM
kelt51f1
Feb 10, 2006 11:48 PM
coburnm
Mar 4, 2004 10:39 PM
