Turned my truck off and wouldn’t start back. It’s an 07 f350 with 149k.
Changed crankshaft position sensor. FICM has 13volts ignition and 50.1 MP volts. Pulling codes for all injectors ( injector A circuit low) with my livewire TS tuner. Will start and run on spray. Any suggestions? I
Positive Crankshaft Position code is very normal when there is a hard start problem. You can ignore it. What motor ?
I would check the fuel pressure and check the battery. I had a hard start problem and it was the battery. Even though it cranked pretty good, a new battery turned it over much faster and no more hard start problem.
