2000 Ford ranger y pipe help
Old Oct 28, 2019 | 01:07 PM
Stephenstaly1's Avatar
Stephenstaly1
So recently I started looking for a terrible exhaust leak. And I finally found it the cats and the y pipe is starting to fall apart and has a couple holes. Nobody sells this y pipe for a 2000 3.0 anymore. Any ideas for something that would bolt up? Don't mind if it's a off-road pipe with no cats just can't find anything everything is discontinued and idk if the 4.0 stuff would bolt up and fit.
Old Oct 29, 2019 | 09:07 AM
CBB9M's Avatar
CBB9M
Any muffler shop in North America should be able to build that y-pipe for you.
Old Oct 29, 2019 | 02:02 PM
ranger pat's Avatar
ranger pat
Veteran: Navy
Check ROCKAUTO, they show several 2000 Ranger 3.0L listed under exhaust catalyst. They are not cheap, but they do have several listed.
Old Oct 29, 2019 | 02:35 PM
Stephenstaly1
Very strange didn't pop up I googled it for two days now. But if that's the case is there a pipe with no cats?
Old Dec 23, 2019 | 08:33 PM
HELMUT RONER's Avatar
HELMUT RONER
No. None without cats. There are for the older square bodies, but none for newer models.
1998-2000 are different from 2001-2003. I just replaced my y-pipe on my 2003 Ranger Edge 3.0L . I looked for weeks before biting the bullet on a brand new Walker y-pipe part number 50203. Runs so much better now, but when I pulled it out of the box from rockauto I was shocked at the amount of wri kles in the bends. I also coated it with high temperature VHT Primer and Aluminum spray paint because the welds will definitely rust later leaving them exposed to the elements. If the factory y-pipe was hogged out I'm sure it would flow better, but I kept in mind that trying to make power with these trucks is like hoping a penguin will fly if you throw it off a cliff. I'd rather take the old y-pipe to where I could get cash for the precious metals in the converters alone. The recyclers won't take chunks of the converter that were punched out. Only whole, unmolested.
rangergolfer
Mar 27, 2018 08:18 AM
handifletch
Modular V10 (6.8l)
20
Apr 29, 2013 10:56 PM
GaryF629
Mar 15, 2013 07:19 PM
danny_g_76
Feb 26, 2009 10:08 AM
beejaytx225225
4 Cylinder Engines
Sep 28, 2003 08:24 AM
