Aerostar Ford Aerostar
Help, high idle
Old Oct 28, 2019 | 06:36 AM
sittinguy's Avatar
sittinguy
Help, high idle
92 3.0 ran fine this morning, got to work and a smooth high idle. A while back I changed to idle air control (not saying it couldnt go bad)
Any ideas? Could the MAF cause this?, I have never touched it.
Old Oct 28, 2019 | 07:16 AM
sittinguy's Avatar
sittinguy
Changed out throttle position sensor a while back also, again could be bad. Its Monday at work and I'm stressed out over this. I would think a vac leak would cause rough idle.
Old Oct 28, 2019 | 10:34 AM
xlt4wd90's Avatar
xlt4wd90
A vacuum leak can definitely cause high idle, but it will usually also throw a code and CEL. And it can run rough under certain conditions. Does the idle speed come down if you disconnect the IAC?
Old Oct 28, 2019 | 10:52 AM
sittinguy's Avatar
sittinguy
Thanks for the reply, IAC disconnect no change. Will be looking around more this afternoon, I can't focus at work at all over this. I already ordered a TPS maybe that is it.
gbrewer
Jan 27, 2015 06:40 PM
Jlckb5
Nov 7, 2011 07:50 AM
94F15094
Nov 1, 2010 02:52 PM
MonatheGrona94
Oct 10, 2008 11:13 AM
