Hinge assembly’s
Old Oct 27, 2019 | 01:32 PM
Budworth's Avatar
Budworth
Hinge assembly’s
Anyone know where I can get a pair of 59 f-100 hinge assembly’s?
Old Oct 27, 2019 | 03:01 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
In 1960, Ford obsoleted the 1957/59 F100/1100 hinges, replaced them with the 1960 F100/1100 hinges. The 1960 F100/1100 hood hinge springs are also different.
No one has any of these 1957/59 or 1960 parts NOS, so used is all you'll find.
Old Oct 27, 2019 | 03:03 PM
oldbleu's Avatar
oldbleu
I have a decent pair set up for the driver's side. You can have them for shipping costs. PM me for further.
Old Oct 27, 2019 | 03:06 PM
NumberDummy
OP said he wanted "hinge assembly's," did not specify if they were for the hood or the doors. Must think we're mind readers.
I listed the hood hinge info, because it's a popular topic in this forum.
Old Oct 27, 2019 | 04:51 PM
oldbleu's Avatar
oldbleu
I thought he was referring to door hinges. You are probably correct.
Old Oct 29, 2019 | 10:37 AM
JohnNewb's Avatar
JohnNewb
What about the springs? Are they available separately? I'm using hinges from donor cab. My old cab hinges had both springs broken.
Old Oct 29, 2019 | 09:08 PM
NumberDummy
What year are the hinges? When Ford replaced the 1957/59 hinges in 1960 with 1960 hinges, they also replaced the 1957/59 springs with 1960 springs.
I would assume that the 1960 springs will not work on the 1957/59 hinges.
Old Oct 30, 2019 | 12:00 AM
JohnNewb's Avatar
JohnNewb
I'll have to look at mine. I noticed when I installed the hinges from my donor f600 that the mount studs were smaller diameter than the f350 hinges. Maybe they were replaced sometime in last 60 years.
timbuctooCal
Feb 5, 2018 12:19 PM
GradyF100
Jul 22, 2015 03:20 PM
