Headlight switch question
Old Oct 26, 2019 | 08:10 AM
RedBox88's Avatar
RedBox88
Trailering
Hi guys !
I've a question for you !
My headlight switch on my 1988 Ford F-250 351 engine is done.
My question is : How many years is this piece made on the truck? Is the 1991 piece fit on the 1988, for example? Between 1988 and 1995 same pieces fit ? I dunno.
Thank your for your anwsers
Old Oct 26, 2019 | 08:56 AM
jas88's Avatar
jas88
1987-91 all take the same switch.
Old Oct 26, 2019 | 10:43 AM
Mudsport96's Avatar
Mudsport96
Not to add confusion, but if you get one from a junkyard, you can grab any year as long as you also grab the connector from that truck. I have a switch for an 89 in my 95 truck. Just used the 89 connector and move the wires to the correct spots.
Old Oct 26, 2019 | 03:59 PM
RedBox88's Avatar
RedBox88
Trailering
Thank you !
Old Oct 26, 2019 | 04:00 PM
RedBox88's Avatar
RedBox88
Trailering
Okay thanks !
Old Oct 26, 2019 | 04:43 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
E7TZ-11654-B .. Headlamp Switch (Motorcraft SW-2103) / Marked: E7TB-AA or AB or AC / Obsolete
1987/90 Bronco II // 1987/91 F150/350, Bronco, Econoline & Ranger // 1988/91 F(Super Duty).
Old Oct 27, 2019 | 08:23 AM
tjc transport's Avatar
tjc transport
i ain't rite
with the way these switches burn out i would never replace with a junkyard switch.
a new switch and wiring connector should be less than around $25 from a parts store.
Old Oct 27, 2019 | 09:35 AM
Mudsport96's Avatar
Mudsport96
I would almost agree with you, but the motorcraft bricknose switch I put in has lasted longer than the last part store switch
kyle.demoss40
Oct 6, 2013 01:20 PM
Bwetzel
Nov 20, 2012 12:40 PM
knash0727
Sep 13, 2008 06:04 PM
htf
Sep 20, 2004 12:37 PM
