2003 Expedition 4wd problems
Old Oct 24, 2019 | 12:42 AM
BMommaerts's Avatar
BMommaerts
Question 2003 Expedition 4wd problems
I have a 2003 Expedition. The 4wd drive switch is round unlike ones I have seen on-line. I watched a few videos concerning removal of the glove box to access the 4wd controller and when I popped the glove box the only thing I see is the fan housing. Could it be located somewhere else?
Old Oct 24, 2019 | 07:55 AM
Hamfisted's Avatar
Hamfisted
On the '03-'04 Expy's the 4x4 control module is located in the driver's side pillar down low, about seatback level. Take the trim piece off and you will see it.
Old Oct 26, 2019 | 02:51 PM
alwaysfords41's Avatar
alwaysfords41
Might be helpful for you to tell what is going on, and why you are after the module.
Old Oct 26, 2019 | 05:29 PM
BMommaerts's Avatar
BMommaerts
No response when I turn the 4wd switch. Fuses in panel are all good. No corrosion around actuator at transmission, and wiring has continuity. I figure the module is a place to go next. You have another idea?
Old Oct 27, 2019 | 09:56 AM
alwaysfords41
It will help people to guide you on this. After switching have you tried driving in a slow circle?
Old Oct 27, 2019 | 01:19 PM
BMommaerts's Avatar
BMommaerts
No dash lights go on when I hit the 4wd dash switch and no power to switch or the relay at transmission. Since there is no activation of the system there is no response when moving at any speed or direction.
Old Oct 28, 2019 | 08:22 AM
alloro's Avatar
alloro
Did you check 30-amp fuse #115?
C0000Lguy
Aug 23, 2015 09:33 AM
Shawn Metoxen
Dec 3, 2014 12:36 PM
Moto Mel
16
Jun 15, 2010 08:51 AM
Beemray
Jul 13, 2004 01:28 PM
stuckinsnow
Feb 11, 2004 02:32 PM
