94 e4od shifting issues
Old Oct 22, 2019 | 09:16 PM
Ford4life!'s Avatar
Ford4life!
Alright, here goes. 94 E350 van (was a uhaul) with a 7.3 idi and e4od tranny. Issues include gear hunting, and wont shift into 1st gear unless you use the column. Shifts up fine but struggles to hold a gear once i try hold a speed over 55mph, even on flat ground. From the research ive done so far it seems like it could be the VSS. Note: the speedo bounces +/- 10 mph. Thanks for any insight!
Old Oct 23, 2019 | 10:29 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
pull the PSOM and check the electrolytic capacitors for leakage
Test your VSS to make sure the resistance is in spec..... generally I don't find bad VSS sensors
Old Oct 23, 2019 | 10:35 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
read the codes from the PCM
fishfreak101
Oct 24, 2019 01:39 PM
CCope94
61
Aug 13, 2012 01:27 PM
jptrader207
Sep 13, 2010 07:09 AM
tskinner
16
Feb 1, 2009 05:29 PM
