adding power brakes
Old Oct 21, 2019 | 03:30 PM
gmrugh's Avatar
gmrugh
adding power brakes
Information needed please, I have a 72 f100 4x4 has drum brakes non power, I bought the brackets and rod from a donor truck, a booster and a new master cly, I´m not getting fluid to the front drums. What is the brake rod length? Mine is adjustable. Or do i need a proportioning valve?
Old Oct 21, 2019 | 07:32 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by gmrugh
Information needed please, I have a 72 F100 4x4 has drum brakes non power, I bought the brackets and rod from a donor truck, a booster and a new master cyl, I´m not getting fluid to the front drums. What is the brake rod length? Mine is adjustable.
Ford: Brake Pressure Differential Valve, your truck already has one (C8TZ-2B257-B), it's the same 1968/75 F100 4WD with or without power drum brakes.
All 1967 and later Passenger Cars, F100/350, Bronco and Econoline with dual master cylinders have it. There are myriad different types.
Old Oct 21, 2019 | 09:33 PM
josht's Avatar
josht
Can't speak to the proportioning valve (I used aftermarket with disc conversion) or the rod between the pedal and booster. Check the rod between the booster and master to make sure that it is the correct length. That's something that will have to be measured and adjusted for your booster master combo.
Old Oct 21, 2019 | 10:29 PM
NumberDummy
Information needed please, I have a 72 F100 4x4 has drum brakes non power, I bought the brackets and rod from a donor truck, a booster and a new master cyl.
What year is the donor?
1967 F100/350: Brake & clutch pedals, bracket they suspend from, master cylinders, power brake boosters, brake pressure differential valves, low brake fluid warning lamp switch are 1967 only.
jtullous
Oct 8, 2011 10:13 AM
CRETE10
Feb 20, 2008 10:02 PM
farmtwuck
36
Oct 9, 2005 08:34 AM
rustyf100
Apr 30, 2003 07:24 PM
72stepside
Feb 11, 2003 11:15 AM
