Oil & Lubrication
oil leaks...
Old Oct 9, 2003 | 10:42 AM
mtm1972's Avatar
mtm1972
oil leaks...
I just put a real oil pressure gauge on my 88 5.0. Since the new sender was bigger than the original one, I had to put a 45 dgree elbow on it to make room. What is the best tread sealant for this type of fitting (brass?) and application (oil)? There's a pretty steady drip out of either the adapter or the elbow so this is the only thing I can think of to fix the problem. Thanks!
Old Oct 9, 2003 | 11:34 AM
jimandmandy's Avatar
jimandmandy
I used Permatex non-hardening gasket cement, no leaks at all. Pipe sealant should also work. Do not use Teflon tape because it may insulate the assembly electrically. A good ground is necessary for it to work.
jim
Old Oct 9, 2003 | 11:42 AM
mtm1972's Avatar
mtm1972
Ok. Sounds good. Thanks for the tip!
-mtm
dkhollins
Mar 25, 2014 06:41 PM
KE8BG
Modular V8 (4.6L, 5.4L)
Aug 21, 2010 11:00 PM
KevinC.
Feb 17, 2010 11:37 AM
John Kiernan
Apr 28, 2008 08:31 PM
TIMM BALDAUF
Apr 19, 2007 05:15 PM
