Fuel selector valve return line
Old Oct 19, 2019 | 07:31 PM
Daniel Botelho's Avatar
Daniel Botelho
8th Gear
I have a 87 6.9 idi The selector valve return line is leaking from where it tees to the return lines on top of the motorThe guy I bought it from put a rubber hose around that plastic line and I can’t tell where exactly it’s leaking from but I’m pretty sure it’s leaking from the top of that tea but I don’t know if what he did was What he did or if that is actually how it came factory
Old Oct 19, 2019 | 07:51 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
get a return line kit and just do the whole return system and be done with it
Old Oct 19, 2019 | 08:25 PM
Daniel Botelho
8th Gear
I’ve already bought the kit but it doesn’t include the line that goes from the selector valve
Old Oct 19, 2019 | 08:46 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
there is only 1 return line going to the selector valve... so all the returns must be Tee'd into one line.
See examples here fuel injection injection pump injection pump rebuilding injection pump repair, Conestoga Diesel Injection Fuel Injection and Turbocharger Rebuilding. The Moose Pump people! Willow Street, PA Fuel line routing options for Ford IDI engines
you can use a Rubber Fuel line to connect to the Plastic line. Ideal Clamps are not the best for doing it... it's better if you use a fuel line clamp that puts even pressure on the hose.. like Pex style or Vapor Guard type clamps.
Old Oct 20, 2019 | 11:16 AM
Daniel Botelho
8th Gear
Thank you very helpful
freightdogfred
Jun 28, 2018 07:27 PM
sean9049
Feb 24, 2015 09:40 PM
pete911
Dec 31, 2011 08:22 PM
jh225
May 11, 2010 02:53 PM
dieselkid
Feb 14, 2010 10:34 PM
