Np435 shifter diameter and original shift boot
Old Oct 19, 2019 | 02:15 PM
DirtyLarry79's Avatar
DirtyLarry79
I need to do something about my ghetto transmission tunnel. I have a nv4500 in place of a np435. The top of my tunnels cut back because the 4500’s shift tower is about 6-8 inches farther back.
Ive got a piece of plate with a box on top kinda covering now but I need a airtight solution for winter. My shifter is also 1.25” or so rod and I’d like to go back to the original thin style.
Could anybody tell me the diameter of the original no435 shifter and what the original boot looks like?
Assuming I can get a replacement for the original. I figure I should figure out what boot I’m gonna use and work my way down. Gonna try to account for the curve of the top of the tunnel.
1979 f250, 400, 2wd.
Old Oct 19, 2019 | 07:19 PM
John89's Avatar
John89
I get 5/8" for mine.
We got our boots from Bronco Graveyard.
Old Oct 19, 2019 | 11:43 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
D7TZ-7277-A .. 4 Speed Shift Lever Boot - Use with Warner T-18 & T-19, New Process 435 / No specs available / Obsolete
1977/79 F100/350 // 1978/79 Bronco.
NOS PARTS SOURCE in Olathe KS has 1 = 913-220-5746.
NOS PARTS LTD in Waxahachie TX has 1 = 972-937-2201.
DON SMITH FORD in Spruce Pine NC has 1 = 828-765-1200.
TISCHNER FORD SALES in Santaquin UT has 1 = 801-754-3281.
Old Oct 20, 2019 | 03:27 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Here you go. Truck Parts and Truck Accessories Top of the page item # 11 and 12 are the norm.
JBG https://shop.broncograveyard.com/197...uctinfo/26037/
Here you go a new un-cut cover, both boots and the one trim ring. Not that you need a 4wd one, so more for a pic of the set up. https://www.ebay.com/itm/FORD-TRUCK-....c100005.m1851
Old Oct 20, 2019 | 03:34 AM
1TonBasecamp's Avatar
1TonBasecamp
I have no idea what criteria was used for changes, but we call out two sizes for them. One was 5/8" and the other 11/16" and we need that measurement for ordering our Gear Banger shifter for proper fit. (https://www.wildhorses4x4.com/produc...d_Transmission)
That little bit of difference may not make any difference in what the boot needs because of the stretch. But for the precisely fitted clamps it's important information.
Paul
Old Oct 20, 2019 | 02:43 PM
DirtyLarry79
So I would need the number 11 boot, and the trim ring to hold it down. Great. Thank you guys very much. I can work with 5/8. My fat shifter is very 80’s-90’s to me.
Will need to order one and build my extended plate from there.
where does the ring go? They want $30 for it and the base of the boot isn’t round, so it doesn’t seem like it goes there.
Old Oct 20, 2019 | 04:51 PM
John89's Avatar
John89
Old picture, but I think you get the idea.
The trim ring tabs go under the carpet or flooring.
We have put in new vinyl flooring, but haven't trimmed the circle/oval for the rings yet. Going to be tedious to get a good fit.
Old Oct 21, 2019 | 12:21 AM
77&79F250's Avatar
77&79F250
The boot is held down by s/m screws. NOT the chrome ring. I have seen the boot put ON TOP of carpet and or vinyl floor. That always cracks me up to see a 10K truck on the web for sale with the boot on top of the new carpet and NO ring. The trim ring is to make for a cleaner edge, if you install the boot correctly. Here is what I mean....the boot is suppose to go UNDER the carpet.
Catlan Zuliani
Nov 24, 2018 10:24 AM
justin_jkj
Jan 18, 2008 11:22 AM
bronco 1996 16 year old
1978 - 1996 Big Bronco
Mar 2, 2004 12:02 AM
ratwell
16
Nov 4, 2002 10:48 AM
