e4od reverse issue
Old Oct 18, 2019 | 10:51 PM
bootless1075's Avatar
bootless1075
e4od reverse issue
yet another reverse issue it is a 1994 f350 5.8 e4od everthing worked good trans got low on fluid do to leaking pan gasket so i droped the pan cleaned it and installed new gasket and filled it with fresh fluid now reverse is very jerky till rpms get up and sometimes it dont want to go in at all any ideas?
Old Oct 18, 2019 | 11:53 PM
dziwei's Avatar
dziwei
Just curious, does it make a clack clack sound when it jerks? I am trying to diagnose something like that, happened once on my '96 after quickly shifting into reverse in the middle of a 3 point turn. But not when I slowly tried to reproduce it backing up, but that time it did squeak a little. I haven't driven it since, checked the U joints in the drive line and they are tight...
Old Oct 19, 2019 | 12:01 AM
bootless1075
the way it felt at first reminded me of the time a caliper bolt came out on the front of my wifes explorer but that is not the problem
Old Oct 19, 2019 | 08:28 AM
Briansshop's Avatar
Briansshop
Did you change the filter? Are you sure the fluid level is correct?
Old Oct 19, 2019 | 10:03 AM
bootless1075
no I did not change the filter the old fluid did look good nothing weird floating in it and the normal paste on the magnet
Old Oct 19, 2019 | 11:36 AM
bootless1075
ok update time i said screw it and floored it and it loaded up the torque converter and can not push the truck feels like its stuck in park and reverse at the same time
Old Oct 19, 2019 | 12:07 PM
My4Fordtrucks's Avatar
My4Fordtrucks
That was my first thought too. More throttle finally gets enough fluid & pressure to get reverse to engage.
Old Oct 19, 2019 | 12:16 PM
bootless1075
any chance it be as simple as the cable out of adjustment
Old Oct 19, 2019 | 12:33 PM
My4Fordtrucks
No. What “cable” did you disconnect to cause it to now not work?
Old Oct 19, 2019 | 12:46 PM
bootless1075
none but the space between park and reverse is non existent and manual first gear dont work but in drive it does
Old Oct 19, 2019 | 05:03 PM
bootless1075
well i adjusted the cable and the mlps and still did not fix i guess its time to put in a new trans
Old Oct 19, 2019 | 08:27 PM
Briansshop's Avatar
Briansshop
Sounds like it might be tear down time. The reverse clutch is applied in M1 and reverse, but a problem with it shouldn't keep M1 from working,the way I see it.
Anyway here's the clutch,band, and one way clutch chart:
Old Oct 19, 2019 | 09:20 PM
bootless1075
well i have a spare trans and now when it shifts into overdrive it feels like im hitting the brakes so id say i have a big issue
Old Oct 20, 2019 | 04:58 PM
bootless1075
driving down the road today and third gear locked up nothing like tires squealing in a trailer park to **** off the neighbors
Old Oct 21, 2019 | 12:42 AM
Da_Lariat_Chariot's Avatar
Da_Lariat_Chariot
Did you bother trying to actually figure out what is causing it instead of "F*** it put a trans in it"? For all you know it will end up being a wasted job and wasted days only to figure out it never needed a transmission in the first place! If I pulled that crap at my dealer they would fire me before I could finish explaining myself! Diagnose the thing or get it to a shop if you don't know how to diag. Sheesh.
