Fuel line replacement now stalling
Old Oct 21, 2019 | 05:16 PM
  #31
427 fordman's Avatar
427 fordman
Originally Posted by 427 fordman
Any cel? How's the wiring to the ipr?
Have you even checked this?
Old Oct 22, 2019 | 01:43 AM
  #32
TURDO's Avatar
TURDO
Originally Posted by knottyrope
buy a scanner?
Think I’m just going to bring it somewhere to have it scanned. I would give to have AE but just don’t have the funds right now
Old Oct 22, 2019 | 08:54 AM
  #33
knottyrope's Avatar
knottyrope
Good luck, most places don't have the right scanners for these
scanner to monitor your engine
https://www.amazon.com/Vgate-Bluetooth-Scanner-TORQUE-ANDROID/dp/B00AAOOQJC/ref=sr_1_1?ie=UTF8&qid=1473776759&sr=8-1&keywords=vgate+OBD2 https://www.amazon.com/Vgate-Bluetooth-Scanner-TORQUE-ANDROID/dp/B00AAOOQJC/ref=sr_1_1?ie=UTF8&qid=1473776759&sr=8-1&keywords=vgate+OBD2
Torque Pro
https://play.google.com/store/apps/d...g.prowl.torque
Use the communication in the profile
SAE J1850-PWM
make sure you add in Ford PIDs
https://play.google.com/store/apps/d...ch.CarGaugePro
people like it cause it will pull codes, buzz test and CCT
Warning, Some OLD PCM's have to be flashed before you can pull codes
Find out your IPR% duty at idle, when its too high it means your injector orings are shot.
links to more
https://www.ford-trucks.com/forums/1...-and-more.html
Old Oct 22, 2019 | 06:15 PM
  #34
TURDO's Avatar
TURDO
It’s just hard to keep throwing things at it and guessing as I am in college and do not have a bunch of time to mess with it. I know ive already said this, but I’m just extremely confused. I would think there would be signs of something with the HP oil system going but I had no signs of anything as it just shut off on me at a red light. I know things break but it’s just very odd that it went from running perfect to just shutting off one day with no signs at all. Haven’t been able to get it running for about 3 days now and I’ve pretty much killed the batteries just trying to crank on it. I called a local shop in Jacksonville called Supreme Diesel Performance and the guy said if I can get the truck there, then he would be more than happy to look over it with me and not charge me, so I’m thinking I might just have the truck towed there and do that.
Old Oct 22, 2019 | 08:03 PM
  #35
farmert's Avatar
farmert
Does the wait to start light come on when you first turn the key to the run position? If not check fuse number 22 in the under hood fuse panel. If it is blown unplug the fuel bowl heater an replace the fuse.
Old Oct 23, 2019 | 12:56 AM
  #36
TURDO's Avatar
TURDO
Yes it comes on for like half a second then turns off. Like just flashes real quick then shuts off
Old Oct 23, 2019 | 03:42 PM
  #37
TURDO's Avatar
TURDO
So I’ve got a really good feeling that because I had such a bad fuel leak that maybe fuel leaked onto the wiring for the IPR and melted the wires together? Or maybe fuel leaked somewhere else shorted something out
Old Oct 23, 2019 | 03:49 PM
  #38
TURDO's Avatar
TURDO
So now my question is, could this have caused my truck to shut off randomly? If a fuel leaked messed up the wiring to the IPR, could it cause the truck to not run at all?
Old Oct 23, 2019 | 04:03 PM
  #39
Hit Man X's Avatar
Hit Man X
Thumbs up
Yes to both questions.
If the IPR circuit goes open, the truck will not run.
Buy a new OE Ford or Navistar pigtail and do what I did - https://www.ford-trucks.com/forums/1...l#post18039915
Old Oct 23, 2019 | 04:34 PM
  #40
TURDO's Avatar
TURDO
Well.... sure enough I pulled that plug that goes to the IPR. Wires were melted together. Pulled them apart and wrapped electrical tape around them to keep them separated. Plugged it back in.... BOOOM, truck fired up immediately and is running perfect again. 😄😄.
Old Oct 23, 2019 | 05:14 PM
  #41
Hit Man X's Avatar
Hit Man X
Thumbs up
I will PM you my address and 427 Fordman's for our beer case.
Miller Lite here please.
Old Oct 23, 2019 | 05:22 PM
  #42
TURDO's Avatar
TURDO
Hahaha sounds good man! Thank you for all the help guys. Glad you guys are here to help. I’m sorry if I sounded a little pissed off at all in any of my posts.
Cheers 🍻
Old Oct 23, 2019 | 06:12 PM
  #43
427 fordman
I've been on a Bud light chelada kick lately. 😁
Glad you got it going.
Old Oct 24, 2019 | 09:49 AM
  #44
oldbird1965's Avatar
oldbird1965
He tried to tell you twice about this but you just ignored him!!
Old Oct 24, 2019 | 09:52 AM
  #45
Hit Man X's Avatar
Hit Man X
Thumbs up
Been sinning a bit... I am addicted to those mango White Claws.
