Recognize this connector?
Old Oct 16, 2019 | 04:57 PM
GoldCo's Avatar
GoldCo
From a ‘95 harness. I thought it was for under-hood light, but both pins go to ground. Black wire and light green / yellow wire.
Thanks.
Old Oct 17, 2019 | 10:46 AM
jas88's Avatar
jas88
Where under the hood is it located?
Old Oct 17, 2019 | 11:40 AM
GoldCo's Avatar
GoldCo
I don't know that it was under the hood — I rec'd all the wiring harnesses from a '95 just dumped in a large box! Last year I spent a bunch of time culling diagrams to figure out what is what, and at some point I labeled this for under hood light… but now that everything is wired up (in my '52) I see that both pins are ground.
My AllData subscription expired, so no more access to diagrams. Not a huge deal, as I can pull power for light from somewhere else easily enough, was just hoping someone might recognize the connector.
Old Oct 17, 2019 | 12:22 PM
mrollings53's Avatar
mrollings53
What else in the harness is it near? What engine? What is "rec'd"?
Old Oct 17, 2019 | 04:17 PM
Bruce W.'s Avatar
Bruce W.
Rec'd = received.
Old Oct 17, 2019 | 09:21 PM
Scndsin's Avatar
Scndsin
In my 94, it is the under hood courtesy light.
My owners manual showing all the other courtesy lights that are always hot are fed by a 15 amp fuse #8.
It runs along with the wiper harness down to the bulkhead connector into the cab.
Old Oct 18, 2019 | 07:57 AM
subford's Avatar
subford
The under hood lamp connector is gray and not black.
Also the wires to it are LG/Y & BK. Not LG & brown.
Old Oct 18, 2019 | 09:51 AM
Binkowski's Avatar
Binkowski
On my '95 F150 with a 302 I can confirm that that connector matches the under hood lamp connector. On mine it is black and has the same wire colors. One side of the connector is attached to about three feet of wire that leads to the lamp, and the other connector is coming out of a larger bundle about six inches from the wiper motor along the top of the fire wall. Hope that helps.
Old Oct 18, 2019 | 10:11 AM
subford's Avatar
subford
I was just going by the 1995 EVTM.
Old Oct 18, 2019 | 11:27 AM
OhioFordFarm's Avatar
OhioFordFarm
In my 89 F250 I have a plug like that near that battery. It is a body ground between battery and body. I'll try to look tonight at the wire colors. I know its two wire. One end goes to a bolt on the core support other to the battery.
Old Oct 21, 2019 | 12:23 AM
TexasGuy001's Avatar
TexasGuy001
Looks like a hood like connector to me also. My 94 has black and green/white wires.
Hesson81
Dec 4, 2018 04:54 AM
ibjew
2009 - 2014 F150
Jan 20, 2018 09:30 PM
KevinPC13
Sep 12, 2015 01:42 AM
DasKroger
Electrical Systems/Wiring
Aug 12, 2014 11:54 AM
