Engine Upgrade
Old Oct 16, 2019 | 03:22 PM
oldblue79's Avatar
oldblue79
Engine Upgrade
I have a 79 f150 4x4 that came with a 300ci 6 cyl. and a D18 transmission . It is my understanding that a 351ci or 400 ci engine will bolt up directly to the bell housing. Am I correct in assuming this swap?
Old Oct 16, 2019 | 04:18 PM
fordman67's Avatar
fordman67
302-351W will.
A 351C would but are more less prevalent.
351m/400 will NOT.
Old Oct 16, 2019 | 09:05 PM
SlikWillie's Avatar
SlikWillie
I would go with a 351W, cheaper performance parts and more to choose from.
Old Oct 16, 2019 | 10:16 PM
broktruk's Avatar
broktruk
Plus, the newer 302, 351w blocks are roller capable so you can use a wide variety of roller cams. Performance parts are relatively inexpensive and plentiful.
Old Oct 17, 2019 | 06:33 AM
oldblue79's Avatar
oldblue79
Thanks for the info should I stay with any certain years when I look for a motor? Or are the newer ones better?
Old Oct 17, 2019 | 09:00 AM
axelgawn's Avatar
axelgawn
I have a modern roller block bored and stroked to a 347 in my LWB 73. Works. great. Unfortunately I still have some wiring upgrades to do since most of its over 40 yrs old. lol
Old Oct 17, 2019 | 09:16 AM
trendyvan's Avatar
trendyvan
Late 93 all 94 96 F4TE starts the casting numbers
Old Oct 17, 2019 | 02:44 PM
SlikWillie's Avatar
SlikWillie
On top of that, you can look for a 5 speed manual transmission to go behind it. Sure, you lose your granny gear but you gain the overdrive.
Old Oct 17, 2019 | 07:29 PM
F-250 restorer's Avatar
F-250 restorer
You will need to move your engine perches toward the firewall. The mounting holes should be in frame/cross member. You may need to change your radiator, depending on where the inlet/outlets are. Alternator, starter, p/s pump, throttle linkage, distributor, etc. will need to be changed.
Old Oct 17, 2019 | 09:53 PM
broktruk's Avatar
broktruk
And you need a 4x4 oil pan. Anyone, correct me if I’m wrong, a fox body oil pan will work if one cannot be located. Been a few years but i seem to recall that i had to use one for my Bronco2 v8 build.
Chewy1978
Sep 22, 2015 01:17 PM
clarktilmon
Jun 6, 2014 10:19 PM
jonathancook81
Oct 13, 2013 07:04 PM
1966 styleside 4X4
May 12, 2010 08:23 PM
Goober
Aug 17, 2000 03:18 PM
