Fuel Gauge Issue
The issue in question is that the fuel gauge isn't working. I removed the middle fuel tank because I couldn't find a seperator worth a damn and recently installed a new tank with sending unit and pump as well as the high-pressure pump and filter... basically replaced everything. I have since not had any issues at all as I did with the dual tank set up (stalling, acting up on WOT, etc.) but the stock fuel gauge stopped working. I caulked it up to maybe the mid-tank wires still there or some kind loose end somewhere. Well, I have pulled the harness, removed the mid-tank wires, double-checked that I had the right wires running from the rear-tank and got a simple aftermarket fuel gauge I am still it is doing the same thing.
But before pulling the harness I tried to simplify the fuel tank selector to what I thought was just the bare necessity. It obviously didn't work because the schematic I found had the rear and front tank wires swapped and heres where things got wonky. As you can see below (and with the crossed-out colors on the schematic I drew) I thought it was the brown and yellow / light blue was the rear tank but it was the orange and brown / white. but the thing is the damn rear pump worked the whole freakin time. The drawing I have above is what it is at now... which includes splicing in the inertia switch. I can't wrap my head around it! Everything still works fine it's just that the gauge doesn't. It does budge a little... so I know it is getting power, it even has it own fuse space (isn't a dual fuse thing). It's almost like the sending units arm is stuck but thats about it. I really don't want to drop the tank because I just finished that dang job (and seriously kicking my butt for not checking beforehand) but that pretty much all I can think it is. I just need a sounding board to make sure my schematics above should work and that dropping the tank to check the resistance on the unit is next. Its night now but I can get a pick of anything tomorrow morning if needed. Thanks for any help!
