Just will not start.....
Old Oct 17, 2019 | 02:43 PM
Olds64's Avatar
Olds64
Lonewolf you da man!
Modding a GP or the HF kit adapter is the way to go. The small fitting in the HF kit worked but it was a PITA. I probably got inaccurate readings which is actually sort of a relief. These were taken on 5/19/2018 with the engine cold and the other GPs still installed:
1) 350 psi 2) 360 psi
3) 340 psi 4) 370 psi
5) 340 psi 6) 380 psi
7) 350 psi 8) 340 psi
It's probably time for me to dust off the HF compression tester, mod the adapter and do the compression test right.
Old Oct 17, 2019 | 09:09 PM
90Ford73's Avatar
90Ford73
Lonewolf that is a great idea to modify a glow plug into an adapter, I knew I was saving these burnt glow plugs for some reason lol
Also not that it matters but just some random info about the fuel shutoff solenoid, my International manual states that a minimum of 9 volts is needed to open it. There’s a little leeway, it’s not like if you have 11.9 volts your thumbing it home, but there really isn’t a reason to not have 12 there I suppose.
Old Oct 17, 2019 | 10:01 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
ya old GP's are handy to make a Luminosity probe adapter too
when using one for compression my Hose has a Check valve in it, and so does my Gauge so I don't need the tire valve in the adapter, anyway keep that in mind.
and Yes I realize that the voltage can drop below 9 volts and still keep the solenoid energized... Pull in is where the max current is drawn and it don't take much to hold it.
this is why I figure it should run long time off a set of good batteries. My guess is 6 volts would hold it once it has been initially Energized
it was in the other post I was a little more bothered by the Low voltage as that Poster said the voltage on the fuel shutoff was dropping to Zero then slowly coming back to 8 or 9 Volts. <<== That just ain't right
Old Oct 18, 2019 | 07:56 PM
cbutcher's Avatar
cbutcher
Got the compression tester this afternoon, pulled all GP, None were any good. Open circuit from blade clip to body.
Cut down the Adapter indicated in the instructions and proceeded to test each cylinder. All but one read 100 the other 230.
Remembered what Lonewolf said and put some light oil in the last one and it jumped up to 500
The truck has not been run since Aug 3, time for some mystery oil tomorrow.
Thanks everyone for your help.
Old Oct 19, 2019 | 07:48 AM
tjc transport's Avatar
tjc transport
i ain't rite
with number like that 5 months ago, i would not even bother retesting unless you think you had something really bad go wrong.
Old Oct 23, 2019 | 06:16 PM
cbutcher's Avatar
cbutcher
Bingo
Finished wet compression test not good 1-450 2-275 3-275 4-300 5-400 6-275 7-500 8-300.
went ahead and installed new GP,
Started with dead truck, added new starter and new glow plugs, fired right up, smoked for a few seconds , idled at about 1000 after a few minutes dropped to about 500 and steady.
Thank you everyone for your input and help.
Old Oct 23, 2019 | 07:05 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
Glad you got her running good job
As far as the compression.... run it for a bit and then re test it... you may have some valves that are not seating very well... but blow out the carbon first and then see...
where you are at .. and if it's running fine don't worry too much about it unless you are OCD like me
Old Oct 24, 2019 | 07:06 AM
Olds64's Avatar
Olds64
x2
If you do another compression test and get similar numbers it might be worth it to re-torque the head gaskets instead of doing an R/R.
Old Oct 25, 2019 | 12:06 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
x2
good point
Old Oct 25, 2019 | 10:36 PM
cbutcher's Avatar
cbutcher
What is the procedure for re-torquing the heads?
Old Oct 28, 2019 | 12:41 AM
DarkOverCast's Avatar
DarkOverCast
Loosen a bolt and then retorque it to the specified max, on my 6.9 international recommends you go 5ft/lbs over since the bolts are used. Do them ONE at a time in the torque sequence. If you Google it you can find the diagram.
Also I'd recommend a bottle of marvel mystery oil in the oil. It'll help any stuck rings free up and clean out the lifters. For best results test compression with the motor fully up to operating temp. Mine saw on average 80psi more per cylinder warm.
What it is cold doesn't really matter as long as it'll start and get warm.
6.9lbluenose
Jun 9, 2019 07:48 AM
pat420swed
20
Oct 10, 2015 09:56 AM
njstevens
Mar 4, 2013 11:21 PM
branden.w
Nov 2, 2009 07:40 PM
branden.w
Oct 31, 2009 12:34 PM
