Fox steering stabilizer
Old Oct 16, 2019 | 02:43 PM
Nick-ApolloOptics's Avatar
Nick-ApolloOptics
Former Vendor
If anyone is looking for the p/n Fox 985-02-132, we have them in stock!
FOX lists this is as one of the two stabilizers available for the 17+ F-250 and F-350. There is a newer upgraded ATS Stabilizer coming out (p/n 983-02-143) and we will have those available in 4-6 weeks.
Old Oct 16, 2019 | 05:24 PM
slapshot12's Avatar
slapshot12
Originally Posted by A&Pmech
Anyone swapped their factory steering stabilizer with this FOX stabilizer:
https://www.amazon.com/Fox-985-24-06.../dp/B01E406D84
If so how did it help with bump steer and vibration? My truck is completely stock and the bump steer is getting bad. It has 10k miles on it, I'm afraid it may be in early stages of death wobble.
I replaced my stock one with a single Fox and the difference was noticeable. I never had any death wobble, but the bump steer is very much reduced.
Old Oct 17, 2019 | 09:03 AM
jwfloyd's Avatar
jwfloyd
I had terrible bump steer with the RC leveling kit. Replaced it with the BDS leveling kit and noticed a significant difference. My Fox Steering Stabilizer P/N 985-02-132 was on back order. Just came in yesterday. I’ll update you on the results after install. I know there is a new Fox SS out that replaces the dual set up. It is a direct replacement of the stock SS. I was told it was overkill for my set up even if I change out my tires to 35s.
Old Oct 19, 2019 | 02:48 AM
TXBulldawg's Avatar
TXBulldawg
I've been running part# 985-24-001 without issue since February. This along with some replacement shocks improved road manners quite a bit.
Amazon Amazon
Old Oct 30, 2019 | 09:08 AM
ExtremeDuty's Avatar
ExtremeDuty
Originally Posted by Joe T
I run the Fox ATS on my 2019. Great improvement over stock.
That and the 2.0 performance series shocks.
They need to break in before you can fully appreciate it.
Might need a couple adjustments on the stabilizer but its easy to turn the adjustment dial. I just tightened mine all the way and backed it off a smidge.
I went that route as well with ATS and 2.0 Fox shocks with the additional change to a PMF trackbar. All this was to try and prevent any symptoms of DW before it happened and the gnawing apprehension that it might happen again. 9000 miles and it feels great. No lift, no level.
P.S. Still have the new in box Lewis Built trackbar for sale. For 2"+ leveling/lift kit. $400 shipped.
Old Oct 30, 2019 | 09:50 AM
Joe T's Avatar
Joe T
I’d list that on the marketplace here. Someone will want it.
Old Oct 30, 2019 | 10:58 AM
ExtremeDuty
Yeah, I listed it in May. Just checked and it's "Expired". Don't know how to restart with out doing it all over.
Old Nov 14, 2019 | 07:01 AM
A&Pmech's Avatar
A&Pmech
This morning I hit a bridge joint and the bump steer lasted for a good bit so I ordered a Fox steering stabilizer. Hopefully it will fix my issues.
Old Nov 14, 2019 | 07:10 AM
17 Oaks's Avatar
17 Oaks
Not likely, may help, but bump steer comes from settings, go to a competent shop and have them adjust your suspension. Bump steer is NOT the same as DW.
Old Nov 14, 2019 | 09:32 AM
A&Pmech's Avatar
A&Pmech
I've seen you preach this over and over. Death wobble begins by hitting a bump. If I can replace my steering stabilizer and greatly improve my ride performance then I'm fine with that. I don't care if it's a bandaid or whatever.
Old Nov 14, 2019 | 09:49 AM
17 Oaks's Avatar
17 Oaks
What in the hell are you talking about, bandaids and bumps????
You are an A&P Mech...YEA, > Southwest Airmotive, Dallas Love Field Local AFL-CIO-IAM, Fuel Injection systems and I thought you were a smart guy.
Old Nov 14, 2019 | 09:56 AM
A&Pmech's Avatar
A&Pmech
What the hell does your credentials as a fuel systems guy at Dallas-Love have to do with bump steer or death wobble?
Old Nov 14, 2019 | 11:18 AM
  #28
17 Oaks's Avatar
17 Oaks
Same as your Mr A&P, stick to your band aids and bumps in the road and hope the hell I don't fly on any plane you were involved in...
Old Nov 14, 2019 | 11:26 AM
  #29
DSLTRK60's Avatar
DSLTRK60
Girls, girls....enough. It is clear what A&Pmech means by bumpsteer. 'Steering feedback' is commonly referred as bumpsteer on the interwebs.
These newer trucks seem to suffer more steering feedback and I believe it to be caused by the reduced caster and changed scrub radius than the Gen 1 SD.
Old Nov 14, 2019 | 11:36 AM
  #30
A&Pmech's Avatar
A&Pmech
So that's the best you got? You are on very one of these threads about bump steer and death wobble and act like you are the all knowing. Numerous members have claimed that upgrading the steering stabilizer helped tremendously with the same symptoms that I experience. Then you come on here stating that it won't help followed by a sorry attempt at criticizing my ability in my profession.
