2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Tailgate lift problems
Old Oct 13, 2019 | 09:10 AM
Jurgen68's Avatar
Jurgen68
Hi, I have a 2012 Expedition with the liftgate lift not working anymore and looking for some help.
All buttons (dash, trunk and remote) will unlock the liftgate only but not lift or down.
It started when I hit something backing up and all I hit was my left tail light. All that broke was the snap/screw taps and so the unit was dangling on the wires.
Even since the liftgate stop working automatically.
If I press any button the lock un-locks but further not even a beeping sound.
so far I did:
Checked in the system if the power lift was enabled.
Checked fuses 14, 17 & 27.
Reset the system by disconnect the battery for over 20 seconds, closed the door and pressed the button.
Removed the motor and when connected to 12v the motor seems to work.
Replaced the lift module but after resetting nothing changed.
Does anyone has more ideas?
Old Oct 13, 2019 | 09:57 AM
seville009's Avatar
seville009
Look at the last post in this thread
https://www.ford-trucks.com/forums/1...sh-button.html
Old Oct 13, 2019 | 03:22 PM
Jurgen68's Avatar
Jurgen68
Seville009, thanks for your replay but that didn’t had any new information.
Old Oct 22, 2019 | 06:22 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
Does the motor appear to try to help lift it? As in: While it should be lifting, try to lift it with your hand. Is it super easy to lift?
Did backing into something cause the door to be misaligned?
Old Oct 23, 2019 | 05:07 AM
Jurgen68's Avatar
Jurgen68
Thanks for your reply.
It seems like the motor is not doing anything not even the beeping sound. All I hear is the unlocking of the door lock (and a few seconds later it locks).
When I removed the motor and applied 12v it was turning smooth.
There was nothing damaged on the bodywork.
Old Oct 23, 2019 | 05:21 AM
seville009's Avatar
seville009
Check the bundle of wires you said the taillight was hanging from. Maybe one worked loose or got crimped or something
Old Jan 1, 2020 | 03:44 PM
Jurgen68's Avatar
Jurgen68
Problem solved!!
Took a visit to the Ford dealer and they tested the car.
They told us that the problem came from the tailgate latch and they could repair it for $600.
I ordered an used one on-line and replaced it.($150)
And surprise, surprise the auto lift started working again.
It acted a little weird going up but all I had to do was resetting the lift by taking the power off the system for a few seconds and preforming a manually lift/closing.
I got a happy wife!.
Old Jan 1, 2020 | 04:46 PM
CathedralCub
FTE Community Team
Cool!
Thanks for letting us know what fixed it!
4x4pwr
Apr 9, 2023 04:31 PM
William
May 10, 2020 05:45 PM
drthornton86
Nov 7, 2017 04:52 PM
kansas gary
Nov 29, 2016 10:34 PM
