Check engine light
Old Oct 11, 2019 | 09:29 PM
Mountainman77's Avatar
Mountainman77
Check engine light
What’s up ford fam. So I noticed my check engine light was on while I was driving home. Normal traffic clear day nothing out the ordinary. I also noticed my trans temp was only around 160 when I got home. After driving home for about 25 minutes. I have a 2016 F- 250 super duty diesel with 89k on it. Does any think the check engine light coming on and the low trans temp are related? And if not what could be some common problems?
Old Oct 11, 2019 | 09:32 PM
Bohen's Avatar
Bohen
Do you have a scanner for your codes?
Old Oct 11, 2019 | 10:04 PM
Mountainman77
Not yet. I will take it in tomorrow
Old Oct 11, 2019 | 10:27 PM
Mountainman77
It came up with a p20ba any ideas
Old Oct 11, 2019 | 11:10 PM
schlepprock250's Avatar
schlepprock250
Reductant (def) heater.
Old Oct 12, 2019 | 08:48 AM
senix's Avatar
senix
heaters are covered under extended warranty, maybe yours is too.
Old Oct 12, 2019 | 02:36 PM
dirthawg's Avatar
dirthawg
You can go to https://owner.ford.com and enter your VIN to see if you have any recalls for the DEF Heater. My truck isn't included in any recalls and my build date is 01/27/16
Old Oct 14, 2019 | 03:11 PM
The Bone's Avatar
The Bone
it takes way more time for the trans to come up to temp. My 15 takes more than 20 miles when not towing. My trans temp hovers around 190 to the same as oil temp. I don't worry about temps to much. Truck has so many safeguards built in that isn't a problem. If you don't have a check engine light than truck is fine. Some of the things guys worry about makes me wonder why they got a diesel in the first place. Sure there were some issues with the early 6.7's but most if not all have been addressed in the 15MY.
Old Oct 14, 2019 | 06:08 PM
Overkill2's Avatar
Overkill2
My 16 is the same as Bone's. At one point there is 60 to 70 degree difference between the engine oil and trans fluid. Sometimes my trans is not all the way up to temp after I get home or work. One way is 18 miles.
Old Oct 14, 2019 | 06:26 PM
Mountainman77
Check engine
Thanks I’ve noticed the trans temp is as you guys are saying. Takes time to go up.
Old Oct 15, 2019 | 09:06 AM
Overkill2's Avatar
Overkill2
Don't sweat the trans temps, it's all good. Let us know how you make out with the CEL...
Old Oct 15, 2019 | 09:35 AM
Mountainman77
Check engine
So just an update. I took my 2015 250 super duty. Dealership said I needed to replace my reductant heater and it wasn’t covered. I’m at 87k.i checked on a customer satisfaction program 18m01 but my truck didn’t qualify. Still don’t know why it didn’t but I even called ford. Thanks to all for the help and advice.
Old Oct 16, 2019 | 11:21 PM
maxum96's Avatar
maxum96
Someone correct me if I'm wrong, but isn't the reductant heater part of the emissions? Shouldn't that be covered under the 5 year / 100,000 mile warranty?
Old Oct 17, 2019 | 02:49 AM
kper05's Avatar
kper05
Emissions warranty is 5 years/50,000 miles.
chrisginco
Apr 25, 2013 04:36 AM
jataos
Jun 19, 2006 12:58 PM
alopez2
Nov 29, 2004 06:54 PM
sty
Aug 13, 2003 04:20 PM
lori_pelzel
May 31, 2002 06:22 PM
