It has 3M tape on the back of the cob lighting but I just cleaned off an area put silicone behind it and a slight bit of silicone on the sides and use my fingers wife off the LED and have had no issues with it coming loose or separating. These are the connectors I used..
Thank you for the pics, brother. Clean under there.
Reason: Add to post
New led's installed will take photos of this evening we shall see how it goes...🤔
I really wish it was a little bit easier to get to the headlight bulbs but I guess it could be worse.
These are my extension cables for my headlights when I hooked it up to a test light the black and red light made it light up for low beam That being said how would I switch these around so that when I turn on the low beam the high beam is engaged?🤔
