Ignition Control Module woes (and win!)
Old Jan 17, 2021 | 03:28 PM
  #31
1TonBasecamp's Avatar
1TonBasecamp
Hey Gloria. I'm not sure which one that might be, but there are a very few of the Ford connectors still available from the aftermarket sources. I've sen some in the local parts stores, but I can't remember what their application was.
Any chance you can post up a pic of which one you're talking about? Is it one of the ones that connects directly to the ICM? Does your ICM have two, or three connectors?
Paul
Old Jan 26, 2021 | 11:03 AM
  #32
black & blue 78/9's Avatar
black & blue 78/9
Bump.
Hoping Gloria remembers to take a picture of the connector.
Old Jan 26, 2021 | 11:08 AM
  #33
black & blue 78/9
Originally Posted by PapaBearYuma
I keep an ICM in the toolbox, AND a stator. I’ve now replaced all three stators:
Your crack is showing!
Sorry for the brain fart and I know I should know. Where is the stator located and whats it do?
Old Jan 26, 2021 | 03:45 PM
  #34
1TonBasecamp
The stator is the part that "stays" in place, so in our case it's the magnetic pickup assembly with the wires sticking out of it. Usually blue, but not always.
The spinning wheel thingy is the armature, sometimes called a reluctor wheel, or rotor (but we usually use that term for the upper "rotor" that we replace during a tune-up) so using the same name for that lower part could get confusing. I think anyway.
When you're testing the ohms reading on your distributor, looking for 400 to 700 ohms between the Purple and the Orange wires, you're testing the stator.
Paul
rsmyre
19
Oct 24, 2018 08:13 AM
daveengelson
15
Nov 18, 2016 08:36 AM
EightGodzillas
34
Jan 8, 2015 03:02 AM
bebeard
Jun 22, 2011 08:14 PM
TNT in Round Rock
18
Oct 29, 2008 09:22 PM
