96 Explorer no heat
Old Oct 9, 2019 | 08:40 AM
tjrtmaster's Avatar
tjrtmaster
96 Explorer no heat
I have a 96 Explorer XLT 4.0 OHV with no heat. When I adjust the temperature adjustment **** I get no change in the heat. The A/C works but I only get fully cold. When on A/C and I turn the temperature adjustment **** the temperature doesn't change, it stays cold. It seems to me that the Blend Door is not opening. Does anyone have a wiring diagram of the blend door actuator and the temperature control ****? How do I test both with a meter for this model?
Old Oct 11, 2019 | 01:24 PM
projectSHO89's Avatar
projectSHO89
Before screwing with anything in or under the dash, get under the hood and check the temperature of the inlet and outlet lines at the heater core. If hot coolant is not circulating though the core, then you'll NEVER have heat, no matter what.
Old Oct 17, 2019 | 11:29 AM
tjrtmaster's Avatar
tjrtmaster
Problem solved. The Blend Door Actuator was bad. I got a new one and plugged it in without installing it. I then moved the temperature adjustment **** and the shaft on the new Actuator moved so my confidence was high that this was the problem. Removing the old one was a major pain. Getting to the one rear screw was difficult but I finally got it and now I have heat. $18 fix.
Old Oct 17, 2019 | 11:55 AM
shorod's Avatar
shorod
Good work, and thank you for following up with what you found. Blend door actuator failures are pretty common on many of the Ford products it seems.
-Rod
hagrid
Apr 28, 2008 03:22 PM
jessica holbrook
Apr 5, 2004 10:44 PM
Matts66
Jan 25, 2004 11:48 AM
klondike1
Dec 30, 2003 10:19 AM
stangz
Nov 21, 2002 10:52 AM
