Suspension and Steering
2.So you don't know what you need? Download a couple of pictures from the net of front and rear steering and suspension showing part names. Then go to Rockauto and build a parts list. Remember most pictures only show one side of vehicle so you'll need 2 of each. If you want to replace everything you'll soon find the parts exceed the price of the truck. See #1.
My '98 is worth about 1800, I have spent about 600 in Motorcraft COP's and rebuilt injectors, spark plugs, starter, battery relay, IACV, JY goodies for odd things here and there. I have clunks and rattles and little noises, just turn up the radio.
My point is that the body is poorly designed and will rust out and never be "worth it" in the end, look under your rockers, pull out those little round plugs, run a pressure washer up there and be astounded by how much truck falls off. The frame is in great shape, the body design is a mud/salt/moisture trap....IMHO.
I have some older trucks that I use to bring on a smile. My '74 and '75 are worth more than my '98...If you are emotionally attached, go for it. If not, drop down into 78-88 if you want something that will be easier to work on and reliable.
On my '98 the PO already chased all kinds of electrical issues, he gave up and I finished the list.
Not just in this thread, it seems to be a reoccurring theme here.
Learning something every day from the forums, I appreciate all the help I have been given.
A lot of newcomers come here for info on maybe their first Ford truck and I think it's better to err on the side
of caution. Of coarse, if they were to show pictures of underneath the vehicle as well as topside they might bet more accurate advice.
That being said, yes ALLORO s link to the front end "KIT" should give you a good idea of the parts required. You can buy cheap or you can be a more expensive kit ( MOOG ?)... depends on if you expecting to get another 30K miles or 100 K miles.
------Package Includes:
1 Front Outer Tie Rod End
2 Front Tie Rod Adjusting Sleeve
1 Front Inner Tie Rod End
2 Front Lower Ball Joints
1 Front Pitman Arm
1 Front Upper Control Arm with Ball Joint Pre-Assembled
1 Idler Arm (With 2.5" Bolt Pattern)
2 Front Sway Bar End Link
4 Bushings Pre-Assembled in the Control Arms
This Kit Fits:
FORD Expedition 1997 - 2002 2WD
FORD F-150 1997 - 2003 2WD
FORD F-150 HERITAGE 2004 2WD
FORD F-250 1997 - 1999 2WD
LINCOLN Blackwood 2002 2WD
LINCOLN Navigator 1998 - 2002 2WD
Besides the "kit" shown above, you might consider new shocks and springs as part of the rebuild.
How about the starter motor , alternator , fan belt, water pump, etc ?? Hard to believe those things lasted 300K ?
1 Front Pitman Arm
This Kit Fits:
But not everyone lives in the rust belt, so old doesn't always equal rusted out. My 69 F250 has had a rough life, but the frame is solid as new. My '85 F250 even has the factory paint on the frame. Rest of the truck has surface rust as the intense UV rays of northern California take out paint jobs pretty easily, but the frame looks great.
Vehicles, new or old, are not good financial investments. Look at this generation of F150s for example; new they were what, 20K-30K? Now you can buy them in the hundreds if you look around. So worrying about putting more money in the truck than it's worth is really a non-sequitur, new or old, if you're talking about value of money they are both bad decisions. Talk to a broker about investments if money gain is your goal.
So you fix up a vehicle for a couple of reasons, you like the vehicle, and/or you like working a project. And even if you dump in as much money into fixing it up than you could have bought a good used one for you're still ahead as you now have a lot of experience and now know the truck inside and out, and it now has a lot of new parts and ready to go for a long time.
For example, if you bought a $1,000 truck and put $4,000 in repairs you have a wealth of new parts and repairs in it when you're done, vs buying a "good used" $5,000 truck that's still sporting all of its 200,000 mile parts in it that you'll end up having to shell out for sooner or later anyway.
Lastly, a project is a good way to "make payments" for one on a budget. You work on it as you can and when finances allow it. If you have a bad month or so you can skip the project for a while. If you're making car payments you don't really have this option.
Anyway, if anyone bothered to read this, thanks.
