Sponsored by: Auxito
hidden chip key
Old Oct 7, 2019 | 05:12 PM
V10man's Avatar
V10man
hidden chip key
I only have one key and I don't want to spend $70 for another one. Couldn't I hide the key close to wherever it needs to be then use regular keys all the time? Would this work? Where is the chip reader located? Thanks
Old Oct 7, 2019 | 05:23 PM
seville009's Avatar
seville009
My recollection from other threads where people were dealing with chipped key issues is that the chipped key had to be pretty much right next to the key cylinder in order for the vehicle to read the signal.
Old Oct 7, 2019 | 05:27 PM
ford390gashog's Avatar
ford390gashog
Actually it used to be common to do this, companies even used to sell the hidden box where you put the Pat's key so their remote start kit would work. In my old 2001 I just removed the RFID vial from the key and glued it in the tone ring and left it in the column cover. I used regular keys for over 200k before I sold it.
Old Oct 7, 2019 | 06:44 PM
projectSHO89's Avatar
projectSHO89
Sure. I've done the "redneck PATS bypass" on all of my older Fords and then just used simple cheap keys for daily operation.
Pull the covers off the column, the PATS transceiver is the ring around the ignition key cylinder. Remove it (one screw) then secure the functioning PATS key inside the ring with a couple of zip ties, then stuff it up under the dash where its well out of the way.
You're good to go unless something important like the PCM or cluster dies then you'll have to have two unique PATS keys to reprogram the new module. Hardware store clones don't count.
Old Oct 7, 2019 | 07:23 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
you should also be aware of the Legal issues IF you do this and the vehicle gets stolen..... Just saying
Old Oct 8, 2019 | 05:57 AM
projectSHO89
The risks are even lower than all of those millions of vehicles that have been driving around for 20 years with a "live" key in a PATS bypass module connected to the remote starter. This is a nearly 20 year old vehicle that probably only has liability insurance on it and no one, except the owner, knows of the bypass. The sky is NOT falling.
Old Oct 8, 2019 | 08:33 AM
Chevy_Eater's Avatar
Chevy_Eater
Damn, you're going to burst a lot of bubbles by informing people the sky is not falling....
Old Oct 8, 2019 | 12:06 PM
Alfred Firmani's Avatar
Alfred Firmani
After giving my 1993 F-150 to charity a few months ago, I bought a very nice 2000 which has this key. I only got one key with the truck. From what I read, I have to pay 70 bucks to get an extra key?
Old Oct 8, 2019 | 12:21 PM
lonewolf_'s Avatar
lonewolf_
Scope Wizard
what I was talking about really had nothing to do with Insurance either.......
I guess it may also vary state by state so sure YMMV....
I was merely referring to "Anti-Theft/key in ignition" statutes defeating a security device falls under this too.... while chances of getting caught up in it are slim you should still know your laws .... https://www.mwl-law.com/wp-content/u...ICLE-CHART.pdf
my statements were not meant to hyjack this thread but just to add some information.
Old Oct 8, 2019 | 04:37 PM
steve(ill)'s Avatar
steve(ill)
Alfred----look in your manual to see how to program a spare key. Newer trucks require TWO keys already programmed into the system to program a 3-4 key............. older trucks required ONE programmed key to program a 2-3-4 key.... Im not sure about a 2000 ...... If you need TWO keys and only have ONE, then you need to go to FORD or Key shop to have a new key cut and programmed.... or you might be able to use a downloaded app on your laptop.
Old Oct 9, 2019 | 08:20 AM
Alfred Firmani
Thanks, I will check my manual, hopefully my truck is old enough!
Old Oct 9, 2019 | 10:54 AM
formerjeepguy's Avatar
formerjeepguy
About $10 for a new key blank. $2-5 to get it cut. $20 for an ELM-327 usb adapter. Free forscan software and also the extended license that lets you access PATS. Program your own keys in 20-30 minutes.
As a bonus, forscan lets you access, read, change most modules on your truck.
Search is your friend.
Old Oct 9, 2019 | 07:23 PM
ondarvr's Avatar
ondarvr
Yours only requires one key, I have a local hardware store that will clone your existing key for $35.
Old Oct 10, 2019 | 05:50 AM
projectSHO89
All F150s from 1999-on require two two unique keys for PATS programming, whether by the end user or when re initializing with a scan tool or equivalent.
Old Oct 10, 2019 | 07:21 AM
formerjeepguy
Clone keys copy the chip id stored in the old key to a special clone key that can have it's chip id programmed. So you end up with what two keys that PATS sees as identical. Just an point of clarification.
