1978 - 1996 Big Bronco
9" regear help
Old Oct 6, 2019 | 11:44 AM
mike86xj's Avatar
mike86xj
9" regear help
I cant seem to get the pattern centered on both sides
if I go thicker than a .010 pinion shim the drive side starts moving to the outer edge of the ring gear and the coast is at the extreme inside.
any ideas?
.010 pinion shim .011backlash drive side
.010 pinion shim .011backlash coast side
No pinion shim .009backlash drive side
No pinion shim .009backlash coast side
Old Oct 8, 2019 | 11:45 AM
Kemicalburns's Avatar
Kemicalburns
call Randy's ring and pinion. they have a great help line. with that said i imagine you have tried youTube right?
Old Oct 8, 2019 | 06:22 PM
mike86xj's Avatar
mike86xj
Ended up going with no shim and opened up the backlash to .012
Cleaned the pinion and re ran the pattern and it looks better than that.
Got her all together and runs smooth and quiet as a mouse.
First regear down now I just have to do the d-44 next.
Old Oct 9, 2019 | 09:34 AM
rla2005's Avatar
rla2005
Looks great to me with your last settings. Thanks for the reply back on what you ended up with.
RojoStar
Aerostar
20
Mar 29, 2022 02:03 AM
annaleigh
Apr 22, 2018 10:25 PM
gman7oh
Jun 5, 2012 01:35 PM
rockher_man
Jun 8, 2009 10:38 AM
