Identify my steering column
Old Oct 5, 2019 | 08:19 AM
Red Dog Rod's Avatar
Red Dog Rod
I’ve just purchased my 56 f100 that had a makeover in the states in 2001 before being shipped over here. My problem is the steering isn’t 56 f100 possibly 80s econoline. Anyway the column change has broken off an is being done by a pair of vice grips the tilt tilts but doesn’t lock and is all just a bit hairy. Any help identifying or even finding a replacement will put you at the top of my Christmas card list. Fingers crossed
Old Oct 5, 2019 | 08:50 AM
56panelford's Avatar
56panelford
Identifying it is the last thing you need to do, yank it out and throw it in the dumpster and order an IDIDIT column.
https://www.ididitinc.com/i-25048070...tegory:1310135
Here is an example from there site.
Old Oct 5, 2019 | 10:20 AM
Old F1's Avatar
Old F1
Looks like a GM to me, ... but I think it is time for a new one.
Old Oct 5, 2019 | 10:45 AM
Red Dog Rod
eBay item 312560563245 is like the one in my truck check bottom bracket bolt pattern. I need to know which one is on mine (splines length equipment)before I order an aftermarket one to make sure it’s going to fit. I’m in the UK so can’t just nip back for a peplacement,couplings,brackets etc.
Old Oct 5, 2019 | 12:16 PM
Tedster9's Avatar
Tedster9
That is the steering column.
Old Oct 5, 2019 | 01:40 PM
Red Dog Rod
I thought that till I saw it’s overdrive and no bottom crumple tube.
Red Dog Rod
Old Oct 5, 2019 | 03:39 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1980 was the first year that F100/350, Bronco and Econoline had the ignition cylinder on the column.
But cars had it before, so there's no way to identify it unless you find a ID paper tag looped over the wires of the T/S switch.
Tilt wheel parts (operated by pressing the T/S handle forward) are mostly the same: 1978/91 F100/350, Bronco & Econoline, 1980 Granada/Monarch/Versailles, Misc 1970/79 FoMoCo Passenger Cars.
Old Oct 5, 2019 | 04:07 PM
Red Dog Rod
Thanks I’ll check for a tag in the morning, but the way it’s been butchered about I don’t hold out much hope.as for the tilt I’ll try that too. Thanks again.
4EVER2
Sep 18, 2019 06:35 PM
78CrewCabHoonigan
Sep 23, 2018 08:18 PM
deich
Nov 18, 2017 01:07 PM
mrgoodwood
Sep 17, 2012 08:25 PM
Myfat52
Aug 3, 2012 05:36 PM
