fuel sender unit
Old Oct 4, 2019 | 03:41 PM
xtal_01's Avatar
xtal_01
fuel sender unit
I have a 1986 F-150 4x4 with a 4.9 six in it. Mid mounted tank.
The sender unit failed years and years ago ... before I even got the truck.
Finally thinking about fixing it (in 5 years I have run out of gas twice).
So, I went on RockAuto ... nothing listed.
Tried a Ford dealer site ... listed one but it had a pump in it. Since I have a carburetor and an old style mechanical fuel pump, I would not think I have a pump in tank. Plus it was listed as discontinued.
Does anyone have a part number and where I can find a sender unit (and I assume the locking ring will be rusted away)?
Thanks .... Mike
Old Oct 4, 2019 | 04:52 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by xtal_01
I have a 1986 F150 4x4 with 4.9L and Mid-Ship tank.
The sender unit failed years and years ago ... before I even got the truck. Finally thinking about fixing it (in 5 years I have run out of gas twice).
E5TZ-9275-G .. 19 Gallon Mid-Ship Fuel Tank Sending Unit - Use without EFI - Use with Unleaded Fuel / Includes E1VZ-9417-B Gasket / Obsolete
1985/86 F150/350 all I-6 & V8 gas engines except 460.
RPN PARTS in Erie PA has 3 = 888-864-9305.
NOS PARTS LTD in Waxahachie TX has 4 = 972-937-2201.
E5TZ-9275-H .. 17 Gallon One Tube Mid-Ship Fuel Tank Sending Unit - Use without EFI / Includes E1VZ-9417-B Gasket / Obsolete
NOS PARTS SOURCE in Olathe KS has 1 = 913-220-5746.
GREEN SALES CO. in Cincinnati OH has 2 = 800-543-4959.
Old Oct 4, 2019 | 07:27 PM
xtal_01's Avatar
xtal_01
AWESOME!!!!!!!!
OK ... just one more dumb question ..... how will I know what tank I have? Since there is only 2 gallons difference I am guessing they look very similar.
Would the truck VIN number help?
I don't think the tank has ever been out (33 year old truck)d.
I did sneak my hand on top of the tank last year .... grounded the tank sending wire and it the gauge moved so I know it is the sensor that is dead.
Thanks ..... Mike
PS .... wonder what the thinking was to have two tanks so close to the same size?
Old Oct 4, 2019 | 09:21 PM
Franklin2's Avatar
Franklin2
If you have a 8 ft bed, you can assume you have the 19 gallon tank. The short beds had the 17 gallon tank.
Old Oct 4, 2019 | 09:52 PM
xtal_01's Avatar
xtal_01
Great!
Yep ... 8 ft bed ... so most likely 19 gallons!
Wondered why two tanks ... didn't even think about a short bed (never had one).
Thanks so very much !!!!!!!!!!!!!!!!
Mike
Old Oct 5, 2019 | 12:15 AM
dagwood57107's Avatar
dagwood57107
My truck is a little older (82) and I got a fuel sending unit on Amazon. Spectra still makes parts and i'm sure you can find one easy there.
Old Oct 5, 2019 | 12:39 AM
xtal_01's Avatar
xtal_01
Thanks .... I just checked and can't seem to find one listed for my truck.
I found their website and have e-mailed the company to see if they do make one.
I hope they do ... about 25% of he cost of a Ford unit.
Mike
Old Oct 5, 2019 | 04:18 AM
FuzzFace2's Avatar
FuzzFace2
The flare side trucks are short bed's and it was even harder to find.
I think I got mine thru A1 Auto and IIRC they listed one for the 19 gallon tank also.
Also note the 19 gallon rear / aft axle tank uses a different sender.
Dave ----
Old Oct 5, 2019 | 01:42 PM
xtal_01's Avatar
xtal_01
Thanks ...
Just check both places ... no longer listed.
Harder and harder to find parts for a 33 year old truck!
Thanks .... Mike
Matt M, PA
May 15, 2016 09:16 PM
Kevin4x4
Jun 15, 2007 06:33 AM
Achelous
Jul 24, 2005 04:25 PM
bigperm2
1966 - 1977 Early Broncos
Feb 15, 2004 05:08 PM
kevinrea
1978 - 1996 Big Bronco
Dec 17, 2002 11:27 PM
