Upper control arm...
Old Oct 3, 2019 | 04:03 PM
Steve_F's Avatar
Steve_F
The ball joints in upper control arms are shot. A lot of play in tire. Do I have to take the coil/shock out in order to replace the upper control arms? Can I simply lift the truck and unbolt it and replace with new control arm and ball joints? Thanks.
Old Oct 3, 2019 | 04:42 PM
Hamfisted's Avatar
Hamfisted
Take the tire off, lift and you can unbolt the upper. All the load is on the lower.
Old Oct 4, 2019 | 04:43 AM
Skauber's Avatar
Skauber
And don't forget to check the alignment when you're done.
Old Oct 4, 2019 | 05:40 AM
broncoholic's Avatar
broncoholic
On my 2003, I had to pull the coil/shock because the upper control arm bolts at the frame were trapped by the top mount of the coil/shock. I even tried to be sneaky by only undoing the top mount and fully drooping the suspension to tip the top of the coil/shock outboard and remove the bolts...nope...the suspension wouldn't droop enough to let me get the top mount out of the bucket. I had to fully remove the coil/shock assembly to replace my upper control arms.
Old Oct 4, 2019 | 03:36 PM
Hamfisted's Avatar
Hamfisted
Broncoholic is correct. Now that I think about it, you do have to get the spring/shock assembly out of the way so the upper control arm bolts will have the clearance to be removed. The whole operation goes better if you have a floor jack or bottle jack available. So you're going to have to remove the three nuts off the top of the shock mount, then with a floor jack take the load off the lower mount bolt and lower the assembly down till you have the needed clearance. The spring is captured on the shock, so it's not going to go flying off on it's own.
Old Oct 5, 2019 | 07:43 AM
Steve_F's Avatar
Steve_F
The spring assembly def has to come out. There’s no way to remove the front bolt for the control arm without the coil removed. It’ll back out 1/2 way then hit the coil.
Old Oct 5, 2019 | 09:38 AM
alloro's Avatar
alloro
Year, model, air suspension or no, 2WD or 4WD?
Old Jan 4, 2020 | 08:38 AM
aircargoo's Avatar
aircargoo
Yes easy if u got tools
Pitgrl1
2004 - 2008 F150
Nov 20, 2012 08:15 PM
SteevenH
1997 - 2003 F150
Aug 11, 2009 01:07 AM
Spotty
1997 - 2003 F150
Oct 3, 2007 09:10 AM
Hartwa
1997 - 2003 F150
Jan 22, 2007 03:27 PM
eigenvector
1983 - 2012 Ranger & B-Series
Nov 10, 2006 09:05 PM
