Starter staying engaged.
Old Oct 2, 2019 | 07:33 PM
Catdaddy601's Avatar
Catdaddy601
1987 f150 4.9L manual trans. Installed new starter and it stays engaged. Why? How can I fix it?
Old Oct 2, 2019 | 08:47 PM
88n94's Avatar
88n94
The power to run the starter must go through the solenoid. Pull the slip on wire off the solenoid and if the starter quits, you are getting power from the ignition switch when you shouldn't. If pulling that small slip on wire off doesn't stop the starter, the solenoid is sticking internally, usually you can tap on the solenoid and the solenoid will release and the starter stop. With the latter you need to replace the solenoid.
warren561
Sep 21, 2019 07:33 AM
Timothy Jones
1978 - 1996 Big Bronco
Apr 23, 2019 01:36 PM
jas88
Nov 16, 2016 07:42 PM
hwknsdrag
Feb 4, 2012 09:13 PM
dirtballer
Dec 27, 2008 01:46 AM
