soft suspension
Old Oct 2, 2019 | 03:18 PM
sono's Avatar
sono
soft suspension
The PO of my 1986 F250 2WD put in Rancho shocks. They are stiff and sporty. I am retired and I am no longer sporty. I don't need the stiffness of a Lotus or a Lola or a Lambo. I would like the mushiness of a Cadillac. Does anyone know what type of shocks to get so that I can soak up the bumps instead of feeling every little one?
Old Oct 2, 2019 | 04:28 PM
FuzzFace2's Avatar
FuzzFace2
First a F250 is going to ride a little ruff as it is a 3/4 ton truck and shocks only keeps the truck from bouncing after you hit a bump.
But I would pick any shock off the shelf from the parts store.
As a note gas shocks will also give a little ruffer ride but the oil under psi keeps the oil from foaming that would cause the shock from doing it's job.
I just installed KYB gas shocks on my F100 from LMC. I have not driven it yet, still building it, but just climbing in & out of the bed it does not bounce like a ball with out the shocks.
I also ran Rancho's, no lift, on a 86 K5 Blazer, duel up front, and I broke 2 left rear mounts and 1 front mount and think it was because how stiff they were but I was also a lot younger then so was not a big deal how it rode.
Dave ----
Old Oct 7, 2019 | 06:31 PM
xlt351's Avatar
xlt351
Trailering
Hey,
I might be completely wrong about this but , I have an 83 F100 ( Australia ) annd replaced both Ftont Springs and new shocks. Its a Truck and it rides like a truck. Very firm.
Ive thought about looking for similar size springs on new model vehicles hoping they would be not so firm but have not done the research.
Cheers
Old Oct 7, 2019 | 06:59 PM
sono's Avatar
sono
Originally Posted by xlt351
Hey,
Cheers
I am sure you are right about your truck but I have owned 5 other trucks. All rode better than my current one. My Chevrolet C10 and K20 rode like comfortable cars. One of my Fords also crashed over bumps (like the current one) but it had a cracked frame. Unfortunately you can only use the right springs on our trucks because there is a 2-1/2 finger gap between the rubber bumper and the I-beam and you have to maintain at least that gap to have any suspension movement.
Old Oct 12, 2019 | 08:42 AM
dagwood57107's Avatar
dagwood57107
I put in a set of KYB Excel Gas shock and am happy. However, mine isnt a F250 here is a
link link
Old Oct 12, 2019 | 04:56 PM
sono's Avatar
sono
Barely affordable.
Old Oct 12, 2019 | 05:04 PM
ford390gashog's Avatar
ford390gashog
Your GM trucks had A arm front suspension much more car like. The Ford with the twin I beam will inherently be rougher.
Old Oct 12, 2019 | 09:37 PM
sono's Avatar
sono
Not the K series: Solid axles and leaf springs. C series: all coil springs. F250 is a real challenge.
evan_nugget
1978 - 1996 Big Bronco
Sep 17, 2019 09:38 PM
Richwon4
Jun 24, 2019 11:39 PM
GreenBean94
13
Dec 7, 2011 02:59 PM
Aune163rd
20
Jan 26, 2011 09:39 AM
